RjPilot
- Joined
- Apr 29, 2005
- Messages
- 21
- Location
- Allgood,Alabama
- Tractor
- John Deere 4310 HST, Kubota RTV 1100
Okay folks here is the problem. My 4310 refuses to move forward or reverse. No obvious
loose wires underneath around the pedals, checked for loose connectors, can't get the
plastic pedal cover off to check around the pedal linkages...how do you get those little
round plastic buttons off of that cover ?
No codes when turning it on or when pressing the pedals...in fact it doesn't even throw
the single blink when turning the key switch ON. I've tried moving the range lever to all
positions and I tried jumping the seat switch connector with no luck.
The mid PTO will not engage, with Operator on seat, brakes off, rear PTO off...again no codes.
It started this stuff yesterday, I did go through some brush, and after working at it
for an hour or so I gave up. Came outside today, and PRESTO it moved fine. Did a little
work and parked it today...PRESTO no move again...hydraulic fluid is full and clear,
fitlers changed about 20 hours ago.
The no codes at start up or when pressing the pedals sounds like it thinks it's operating
properly, so does this sound like a seat switch or do I need to just cut the plastic
buttons on the pedal cover to get it off, and check the connector inside there ?
HELP.....
So I'm thinking that it just about has to be a seat switch...otherwise the mid pto would
engage...the rear pto works fine when on or off the seat, just as designed.
HELP.....
