Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    New Member
    Join Date
    May 2010
    Posts
    2
    Default dropped aplastic gas cap into gas tank JD LA135
    oops! I dropped a plastic gas cap into the gas tank on the riding lawn mower. I think it sunk....
    Can I continue to use it and then try and fish it out once all the gas is gone? Or do I need to get it out now? I need help! Any ideas?
  2. #2
    Super Member dcyrilc's Avatar
    Join Date
    Nov 2009
    Posts
    5,490
    Woodinville, Washington
    John Deere 2240 MFWD
    Default Re: dropped aplastic gas cap into gas tank JD LA135
    Shouldn't be any problem just leaving it in there for now. Later, when the gas is lower, you can get a pair of the finger things that come out of the end of a metal flex tube (http://www.idealtruevalue.com/servlet/the-24067/Detail) and with a flashlight pull it out when it's visable.
    Cyril
    JD 2240 MFWD (with duels now)
    145 FEL, 8ft Rear blade (now I need a 12ft blade)
  3. #3
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Are you kidding? I dropped the whole nozzle, springs and all, off one of those stinky auto open cans into one of my tractor gas tanks. Don't worry about it, it's nothing.
    Rob
    Rob
  4. #4
    New Member
    Join Date
    May 2010
    Posts
    2
    Thanks! I just wasn't sure and didn't want to ruin anything first and ask questions later
  5. #5
    Silver Member Barely Smokin''s Avatar
    Join Date
    Mar 2009
    Posts
    103
    Nelson County, VA
    1952 JD 440 backhoe, JD 790
    I doubt it would ruin anything. I suspect product liability-wise, any plastic part of a gas container is rated for full and continuous immersion in gasoline with zero degradation. Gotta be.
    But, next time your tractor suddenly dies even though it's full of gas, you'll know why. Wouldn't take me long under those circumstances to fish that sucker out of there, using the method dcyrilc described. Just don't drop the flashlight.
    JD 790 w/FEL, Frontier 1060 FM, BB, SP, RB, PHD, forks and log splitter
    JD 440 rubber tire FEL and BH
    Caterpillar D4D
  6. #6
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    Quote Originally Posted by Rob-D View Post
    Rob
    Just did the same thing, and on mine you cannot see the tank from the top, it so I gotta figure the best way to get it out. I think I will get another thread going
    Nuru
    JD 3520
  7. #7
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Quote Originally Posted by Nuru View Post
    Nuru,
    Mine sat in there a couple of years and then I sold the tractor. Not much can happen that I can see. Does it have an metal on it? Maybe you could drop a powerful magnet down there if it has a spring on it. You could drain the tank, take it off, and shake it out but that's a lot of work.
    Rob
  8. #8
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    Nuru,
    Rob
    Rob, Hmmm ,a magnet, did not think of that, there is a spring or springs in that assembly. The issue I have is that it is now preventing me from using my MMM, as every time I try to use it, if just cuts off the engine. Runs fine when I don't try to use the MMM.
    I wonder if a big magnet can attract it and allow me to slide it up the tank into the upper section?
    Nuru
    JD 3520
  9. #9
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Nuru,
    My guess is that right now it's at the lowest point in the tank right by the outlet.
    Can you see it with a flash light?I'd try to snag it with a magnet and have a coat hanger with a 'U' at the end to slide through the nozzle hole. It seems to me that I could see mine if I looked into the tank with a light. These tanks are black, too bad they aren't the type you can see the gas in!
    If you can see it with a strong light you may be able to get it with the bent hanger. Also see if you have a nozzle on another can you can probe with a magnet to test it. It depends on the the stainless steel springs, some have more nickel in them than others and magnets don't work well.
    You may even be able to probe around in the dark with a hook and get it in the nozzle hole.
    Rob
  10. #10
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    Nuru,
    Rob
    Rob, thanks, take a look at the pic I posted on the other thread, poking around needs to be done with vision as that sending unit can get snagged by poking around in the tank without being able to see.
    Nuru
    JD 3520
Similar Threads
  1. Oil & Fuel Spout cap in gas tank
    By kwolfe in forum Owning/Operating
    Last Post: 06-22-2009, 09:26 AM
  2. Gas Tank needed 1953 Ford NAA
    By GuglioLS in forum Parts/Repairs
    Last Post: 09-28-2006, 12:48 AM
  3. Oil & Fuel fuel can nozzle part dropped in fuel tank
    By wilkesland in forum Owning/Operating
    Last Post: 07-28-2006, 02:36 PM
  4. Dropped a couple cups into the tank.
    By RalphVa in forum Owning/Operating
    Last Post: 12-22-2004, 05:46 PM
  5. Gas Grill Propane Tank
    By RobS in forum Related Topics
    Last Post: 09-07-2004, 09:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
