Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    2,352
    MO
    John Deere 1953-40S, 790, 755, 314, 70 I & Power King 2418
    Default JD Quick-Attach Brackets
    Does any body know of a source for the "weld-on "hooks" to make other attachments for the 300 loader? I can make my own, but it would be easier to buy "ready-made" if they aren't too high. ~~ grnspot110
    Attached Thumbnails Attached Thumbnails JD Quick-Attach Brackets-farm-026-small-jpg
  2. #2
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Default Re: JD Quick-Attach Brackets
    I thought about those too.
    What I decided was to make them by cuting a pipe section and welding parts to it. Not as hard as it sounds, maybe a half hour job.
    Rob
    Rob
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,015
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    Don't quote me, but I thought you could buy those through JD.
  4. #4
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,936
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    I thought so too.
    But over the years, there have been several posts in TBN threads on these brackets. I think it is the best system going. Light weight (especially compared to the skidsteer bracket offered as a Deere option) and easy to attach.
    Maybe a search will pop up some good ideas for OP.
  5. #5
    JCB
    Guest
    Grnspot,
    You can get them from JD parts. A couple years back I got those brackets and the lower pins. I got them for 200 loader, but I think it's the same parts for the 300. I think the whole set was only around $60. I definitely thought that was easier than building the parts.
  6. #6
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    You can buy the "hooks" and "pins" from JDParts...The #'s are:
    W47211 PIN,
    W43359 HOOK, BUCKET
    Or you can make your own with angle iron and CAT3 pins, see attached pictures.
    Attached Images Attached Images
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  7. #7
    Join Date
    May 2007
    Posts
    2,352
    MO
    Thanks for the #, I'm working on a set for a 5' boom, but don't have all the iron I need on hand. Have to wait on that 'til Monday. Found the hook on jdparts, $11.99, not really that bad!
    I'm cutting up a 3-pt boom I had to make the 5' boom, 3-pt part will make the base for a weight unit. I've got 70# of railroad rail & 2-100# suitcase weights, will make a good start! ~~ grnspot110
  8. #8
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Nice restore on the Clausing Kenny! What's the swing?
    Rob
  9. #9
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,382
    NW Oregon
    Deere 317 & L118
    sounds like a fun project. As you know on TBN, we liked pics!
    My Fleet:
    2004 Bobcat 430G Excavator
    2006 Bobcat T140 Compact Track Loader
  10. #10
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    Quote Originally Posted by Rob-D View Post
    Thank you, it's a 10" x 24".
    KennyD
    www.boltonhooks.com
Similar Threads
  1. Quick attach brackets?
    By caddison in forum Attachments
    Last Post: 02-07-2010, 11:40 PM
  2. B7100 Quick Attach
    By charlz in forum Build-It Yourself
    Last Post: 02-05-2010, 09:34 AM
  3. Broke my quick attach pins!
    By JRobyn in forum Attachments
    Last Post: 09-08-2006, 03:30 AM
  4. FEL bucket conversion to a Quick Attach???
    By Bob_Skurka in forum New Holland Owning/Operating
    Last Post: 09-27-2004, 02:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
