My property is very sloped with grade changes abound. I rarely get to mow in a straight line for very long. In some spots, the mowing deck will actually bottom out up against the tractor on one side as I squirrel up an off camber turning rise. When the mowing deck bottoms out against the tractor, I hear a clicking sound from below.
I've always figured it was the PTO shaft grumbling a bit or maybe something in the pulley system. I just try to avoid it or reposition when it happens.
A couple of weeks ago while lubing up under the tractor, I noticed some nicking on the bottom edge of the metal shroud around the infamous plastic cooling fan. I thought "Oh wow, I must have come close to hitting the fan with a branch or something" and the priority for getting protection got stepped up a notch but I otherwise dismissed it for the time being.
Well, I had a thought this morning. I think what might be happening is that when the mowing deck is bottoming out against the tractor, the gearbox on the mowing deck might be hitting the fan shroud and causing the plastic fan to rub slightly.
Has anyone else noticed this or made this connection? I'm going to try taking a closer look as soon as I get a chance but I was wondering if anyone else has heard this clicking sound while mowing. I'll get pictures, don't worry.
