Results 1 to 9 of 9
  1. #1
    Join Date
    Mar 2005
    Posts
    947
    central Illinois near Lake Shelbyville
    Case 2090 Massey Ferguson 4233 John Deere 4700
    Default 3 point hitch is slow lowering
    My 755 all the sudden is slow to lower the 3 ph. I have looked in the book and it does not mention anything about a valve to control the speed of drop like my 4700 has. Anyone have any ideas at what it could be?
  2. #2
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    Default Re: 3 point hitch is slow lowering
    Raise the seat and look under the left side. There is a large knob close to the left fender. That is the rate of drop control.
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  3. #3
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    From the manual.
    Attached Thumbnails Attached Thumbnails 3 point hitch is slow lowering-rate-drop0001-jpg
  4. #4
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,286
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Quote Originally Posted by JD755 View Post
    From the manual.
    JD755, you are my hero!
    (nice posts!)
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  5. #5
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    Quote Originally Posted by RoyJackson View Post
    (nice posts!)
    Thanks Roy. Just like you, always glad to help where I can.
  6. #6
    Join Date
    Mar 2005
    Posts
    947
    Well I checked the valve and it was all the way open. I checked Hydralic oil level and it was fine. I did notice as the temp outside dropped this evening the better the 3 ph worked. It raises just fine. It is just lowering it that is a problem. I was bushogging some pretty tall grass and working it pretty hard. I did not over work it but was working it. The temps here today was around 90. I was wondering if it would have anything to do with the hydralic oil temp. I also blew out the radiator and oil cooler as it was getting a lot of trash in it from mowing tall grass.
  7. #7
    Join Date
    Mar 2005
    Posts
    947
    I called my John Deere dealer today and he said it sounds like a heat problem. I am going to try and blow out the cooler real good and wash it. If that does nto help I am not sure what to do. I did not use it tonight but I did start it up and the 3ph dropped like it should.
  8. #8
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    Agree with checking for heat problem first. Looking through the tech manual problem could be the lowering check valve. Looks like not too hard to work on. Or the stop valve itself.
    Attached Thumbnails Attached Thumbnails 3 point hitch is slow lowering-check-valve1-jpg   3 point hitch is slow lowering-check-valve2-jpg   3 point hitch is slow lowering-check-valve3-jpg   3 point hitch is slow lowering-check-valve4-jpg   3 point hitch is slow lowering-check-valve5-jpg
  9. #9
    Member
    Join Date
    Aug 2009
    Posts
    49
    JD 4200, JD x360, JD z950r JD x739
    Had the same problem with my 4200 last year. Come to find out it was a small o-ring that had a little cut on it. Seems to me it was on the check valve also.
Similar Threads
  1. 3-Point Hitch MF 3635 3 point hitch
    By brandon327 in forum Massey Ferguson Owning/Operating
    Last Post: 09-18-2013, 10:16 AM
  2. 3215 3 point hitch
    By MrChris in forum Mahindra Owning/Operating
    Last Post: 05-08-2010, 10:52 AM
  3. 3 point hitch hitch and then some.
    By Chances R in forum Build-It Yourself
    Last Post: 09-05-2009, 10:37 AM
  4. 3 point hitch & land pride quick hitch
    By shrekbelly in forum Kubota Owning/Operating
    Last Post: 08-06-2009, 06:35 PM
  5. B7500 3 point hitch hydraulic problem
    By dannyk in forum Kubota Owning/Operating
    Last Post: 08-25-2004, 06:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
