Dirt Moving Make-shift Box Blade
   / Make-shift Box Blade #1
grnspot110
Elite Member
MO
John Deere 1944- H, 1961 Cub Lo-Boy, 2016- JD 2025R, 2018- JD X580
Finished up my "make-shift box blade today!:) One 5' King Kutter "XB" 3-pt blade, 5' of heavy wall 2" square tubing, two 1' x 2' x 1/4" steel plates, a few bolts, a few pieces of scrap = box blade! I already had the blade, which I didn't use, $55 worth of steel & a little time welding.
If I decide I need scarifiers, I'll add them with another cross-member later! ~~ grnspot110
   / Make-shift Box Blade #2
That's one way around making a trip to the local dealer - nice job ! If you add the scarifiers, you might need to make the right/left pins into clevis mounts, but I think would be a simple task for you.
   / Make-shift Box Blade #3
Nice job making do with most what you have.
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
1026A (A58374)
1026A (A58374)
