Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jun 2010
    Posts
    1
    Default 4200 my bucket won't stay up
    My front bucket seems to work fine in all modes. it's only when the bucket is full that it lowers very slowly. is this just low fluid in the hydrolic system,
    I can't see the sight glass as the backhoe is on
  2. #2
    Gold Member
    Join Date
    Dec 2001
    Posts
    292
    Virginia, Eastern Shore
    JD 4300
    Default Re: 4200 my bucket won't stay up
    Almost all buckets will drop over time. A full bucket will drop faster.
    It is called "leak down" I believe and is natural unless it is too fast and interferes with your work. If it is too fast you may have a hydraulic leak. There is a rate of drop adjustment for the 3 point hitch but I do not believe there is anything for the fel that will control the drop rate.
  3. #3
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,857
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Yep, I was bushhogging yesterday with the FEL on it would slowly drop down about a foot or two every 20 minutes or so. It happens slow enough that if you're not paying real close attention to keep it up, it could get low enough to hit something (stump or dirt mound). That was with it empty of course, so I'm sure it would drop quicker if there were anything in the bucket.
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5ft King Kutter II Rototiller, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  4. #4
    Member
    Join Date
    Jun 2008
    Posts
    38
    you need seal kits in at least one of your bucket cylinders. they are leaking internally. the seals on the piston are out. you can buy the seal kits and do them yourself. tear them both down and rebuild one at a time. while they're disassembled, inspect the cylinder bore for any deep scratching. no seal kit will fix a cylinder scratch. if you're not sure how they come back together, jdparts.com will give a cylinder blow up. any tractor dealer with a decent service dept can rebuild it for you if you get the parts.
    good luck!!
Similar Threads
  1. Replies: 14
    Last Post: 09-11-2013, 10:40 PM
  2. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 05:12 PM
  3. Is it just me, or does this go too far?
    By MessickFarmEqu in forum John Deere Buying/Pricing
    Last Post: 12-10-2008, 10:41 AM
  4. Wide-Angle Bucket -- Swap for a regular bucket?
    By mundamanu in forum Attachments
    Last Post: 07-29-2004, 01:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
