Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jun 2010
    Posts
    5
    Lakeville, Nova Scotia
    JD 2320
    Default Are these the correct lift arms?
    Hi everbody. Just bought a new 2320 with FEL and BH. I have some questions about the 3pt hitch. The tractor arrived with the BH attached and the lift arms etc in a cardboard box marked as for a 2720. Dealer doesn't have another 2320 on the lot at the moment so I can't do a direct comparsion. Hopefully the attached pics will help. Also is it obvious if there is fluid in the transmisson sight glass? I can't tell if it is completely full or empty. I can't see a bubble. I wonder if it may be low as the tractor seems to be noisier then the 2720 I tried out first. Is there a way to tell model year based on serial #? thanks for any and all help.
    Attached Thumbnails Attached Thumbnails Are these the correct lift arms?-img_0435-jpg   Are these the correct lift arms?-img_0436-jpg   Are these the correct lift arms?-img_0441-jpg   Are these the correct lift arms?-img_0442-jpg
  2. #2
    Platinum Member B8FISH's Avatar
    Join Date
    Jan 2004
    Posts
    589
    West Bloomfield, NY
    JD 3320
    Default Re: Are these the correct lift arms?
    The sight glass has a white background, with (usually) amber colored fluid being visible against the white--if you are seeing all white you may want to do a fluid check and fill. On the arms--I can't tell you if they are the correct part number--they look Ok--but I'm sure they look used!
    3320 300CX w/teeth, 448BH, MX-5 ,5' BB, 6' rear blade, JD 757ZTR, MS261, MS211
  3. #3
    Member snyder_man's Avatar
    Join Date
    Aug 2009
    Posts
    26
    Ohio
    JD 2520, JD425, Sold IH 244
    Those certainly look like used lift arms off a 2720 to me not a 2320 or 2520.
    The 2720 has the bend and welds on them.
    snyder_man
    "It's tough when you have caviar tastes but only a filet-o-fish budget"
    JD 2520, 200CX FEL, 62D MMM, 54" snowblower, 647 Tiller, 5' BB, 4' Scraper, FEMCO Sprayer
    JD 425 AWS, 54" deck
  4. #4
    Platinum Member glc24's Avatar
    Join Date
    Dec 2009
    Posts
    896
    Southwestern, Pa.
    First pic is the new style arm for the 2520 and 2720,the second pic is the older style arms for these two tractors.
    I don't know what the OP arms are off of. They sure aren't from a 25 or 27.
    Could they actually be 2320 arms?
    Greg
    Attached Thumbnails Attached Thumbnails Are these the correct lift arms?-lower-arms-jpg   Are these the correct lift arms?-tractor-pics-old-arms-2-a
    2009 2520
    FEL/61" HD bucket/replaceable cutting edge
    62D2 MMM
    IMatch Quick Hitch
    Homemade 3PT Receiver
    Homemade Ballast Box
    Woods GB65 Box Blade
    A "REAL" snow blade --- JD 380A
    90% Restored 1987 JD 316
    MY BALLAST BOX:
    http://www.tractorbynet.com/forums/b...box-build.html
    MY SE SEAT 2520 MOD:
    http://www.tractorbynet.com/forums/j...my-2520-a.html
Similar Threads
  1. adjusting 3pt to lift higher
    By defed in forum John Deere Owning/Operating
    Last Post: 03-30-2010, 10:48 PM
  2. DF-354 lift arms not parallel....did I break something?
    By mpaschetto in forum Chinese Tractors
    Last Post: 04-14-2009, 10:24 PM
  3. Trouble with lift arms (1401D)
    By jrbowhuntr in forum Yanmar
    Last Post: 02-20-2009, 06:05 PM
  4. Two lift arm holes on 3ph arms on 4010/4110
    By RalphVa in forum John Deere Owning/Operating
    Last Post: 05-27-2008, 01:12 PM
  5. Home brew boom pole
    By cityfarma in forum Attachments
    Last Post: 09-06-2007, 09:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
