yooper68
Member
Took my 3-point hitch off last evening; working to install 375 backhoe mount plates. The ball on the lift link did not want to come off the pin on the rockshaft lift arm. Upon closer inspection, there was a small "shoulder" worn into the pin from slop/play. I touched the right side with a grinder to remove the "shoulder" and it came off no problem. The left side took a lot more grinding and filing and looks like it was bent slightly; also has a crack through 1 side of the hole where the quick lock pin goes. My question is; how difficult would it be to replace the pin (JD part # M136549) and the ball (JD part #T21901)? That pin seams stuck in there very tight; do I have to take the entire arm to a shop where they have a press? I wonder if replacing the pin on both sides would be enough, or if I should also replace the ball since there appears to be a little play there? Tractor is 06 model with 500 hours, mostly snow removal with loader and backblade and running brush hog.
