Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jul 2010
    Posts
    1
    John Deere 950
    Default 950 Does clutch need adjusted or replaced?
    I have an older John Deere 950 - the one with the single clutch which operates PTO and drive simultaneously. Lately, I have noticed a delay in getting the tractor to move once I let off the clutch pedal. It basically feels like it is slipping some and then will finally engage. I experience this more when in HIGH than in LOW. If I am on a hill (steep) I have considerably more difficulty getting moving. Is this something that can be adjusted or does it in fact need replaced?
    Thanks much for your time.
    Chris
  2. #2
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    Default Re: 950 Does clutch need adjusted or replaced?
    Where in the clutch pedal travel does it start to engage? Usually once a clutch shows the symptoms you describe the clutch is shot.
  3. #3
    Join Date
    Dec 2001
    Posts
    1,336
    Maryland
    Do you have any "free travel" in the clutch pedal? You should have about an inch of travel when you first push in the clutch that is very easy to push. Then it should get stiffer. If you have no free travel, then you can proably shorten the adjustable link connected to the pedal to improve your clutch operation. Shorten it untill you have an inch of easy pedal movement. You should be able to push this free travel with one finger. If you do have free travel and it still slips, then it's time for a new clutch.
Similar Threads
  1. Ford 1920 clutch Help needed
    By MIkeWard in forum New Holland Owning/Operating
    Last Post: 02-28-2015, 10:42 AM
  2. Smoking Slip Clutch
    By OverlyRun in forum Attachments
    Last Post: 03-28-2011, 08:46 PM
  3. 61 hrs and the clutch is gone!
    By Neuropel in forum Chinese Tractors
    Last Post: 05-27-2005, 01:19 AM
  4. Kubota L2250 Clutch Problem.
    By DanCook in forum Kubota Owning/Operating
    Last Post: 04-05-2005, 08:53 AM
  5. clutch
    By vaughan in forum Kubota Owning/Operating
    Last Post: 10-19-2002, 10:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
