Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2004
    Posts
    93
    KY
    JD 323D
    Default 110 TLB-Installing/Removing 3PH
    Just looking for advice or feedback on how involved the 3PH installation is? Since the BH is on, I'm trying to get some projects done with it before I make the switch to 3PH operation. Right now, everything looks like a hole to be dug, but I need to make room to take the backhoe off and put on some other attachments.
    Most important is getting my splitter hooked up.
    Thanks!
  2. #2
    Super Member
    Join Date
    Feb 2008
    Posts
    7,738
    somewhere usa
    stuff
    Default Re: 110 TLB-Installing/Removing 3PH
    Usually it is a five to ten minute job for me to remove the hoe since I have a cab on mine. Installing the three point hitch takes another five minutes.
    When I remove the hoe I do block it up with wood blocks incase the cylinders leak down some. I also clean and grease the large upper pins to make them slide in easier.
    Once you do it a couple of times it is a simple thing to do.
  3. #3
    Elite Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    4,860
    Kasilof, Alaska
    JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
    Removing and re-attaching the hoe takes less time than hooking up the 3pt. Dropping the hoe takes 2 minutes and it's about the same to pick it up again.
    Because I have the top n tilt for my 110; routing (wrestling) the hyd hoses and the cylinders is more of a challange than the hoe - IMO.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
Similar Threads
  1. 110 TLB and hammer
    By GreatWhitehunter in forum John Deere Owning/Operating
    Last Post: 08-31-2009, 06:37 PM
  2. JD 110 TLB Backhoe Buckets
    By aradsma in forum John Deere Buying/Pricing
    Last Post: 06-10-2009, 10:57 PM
  3. 110 TLB vs 4x20/485BH
    By skidoo in forum John Deere Buying/Pricing
    Last Post: 12-01-2008, 09:05 PM
  4. 110 tlb Problems
    By mikeyp in forum John Deere Owning/Operating
    Last Post: 09-30-2008, 03:40 AM
  5. 110 TLB Questions
    By NFA Fun in forum John Deere Owning/Operating
    Last Post: 05-31-2007, 09:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
