Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2010
    Posts
    52
    angleton texas
    John Deere 990-4700-5310-new holland tn65-Ferguson to 30,1951-to30,1954, ford 2n 1947, ford 2n 1943
    Default 5310 backhoe
    I just bough a 5310 JD with front end loader.
    I wan to use my backhoe behind this one, what is the best (most cost effective way) to install power beyond on the 5310?
  2. #2
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Default Re: 5310 backhoe
    Quote Originally Posted by picanoor View Post
    Welcome to TBN! Look here -- https://jdparts.deere.com/servlet/co...=UNSIGNED_VIEW
    You'll need to register. But, you should be able to find the Power Beyond circuit for your 5310; including a diagram showing the revelant parts and price.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  3. #3
    Join Date
    Aug 2010
    Posts
    52
    angleton texas
    Thanks,
    i went trhough this site but am not sure if i need to add a power beyond valve, and which one.
    when I added the power beyond to my 990 i bought a kit from john deere which included some lines and Scv conecters, no valve.
    installation was quick and simple. is this option also available for a 5310?
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Thanks,
    Yes, you need Power Beyond. It's not a "valve", just a set of lines that provide continuous flow whenever the tractor is running. If you look in JDParts, look under "P" for power beyond, there are several listed depending on which SCV configuration you have. The one below is for 0 or 1 rear SCV's.
    There is a quick tutorial linked in my signature if you need help with JDParts.
    Attached Thumbnails Attached Thumbnails 5310 backhoe-5103-gif
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Join Date
    Aug 2010
    Posts
    52
    angleton texas
    thanks for the in info,
    finally got the tracor shipped to the house and did some checking.
    i have 2 sets of remote scv on the back connected to my front end loader, the valve block has 3 extra connections capped off on right side (wheel side).
    if i look up the power beyond coupler kit ( with 2 or 3 scv) the kit has hoses for 3 couplers:
    one to male quick connect.
    one from bottom of block to hose to male quick connect
    and then one that is going from bottom of block to a female quick connect. these are looped together.
    the last one from top back of block to male quick connect where do i use that one for? eaxtra return leak oil line? see attachment.
    Attached Thumbnails Attached Thumbnails 5310 backhoe-lvp7995________un27mar07-gif
  6. #6
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    The "extra" line should be a direct return to the sump/tank, bypassing the 3PH since you don't want it active while the backhoe is mounted.
    KennyD
    www.boltonhooks.com
  7. #7
    Join Date
    Aug 2010
    Posts
    52
    angleton texas
    ok thanks,
    i do have an overflow /pressure relief valve and line coming from my backhoe block which right now blows the oil to the ground, so i can connect it to this one.
Similar Threads
  1. Backhoe Can a BX2660 Be Fit w/ a Backhoe Later... like the BX25?
    By robertm in forum Kubota Owning/Operating
    Last Post: 11-30-2013, 02:59 PM
  2. Backhoe Anyone ever use a CUT mounted backhoe to dig a foundation?
    By Lt CHEG in forum Attachments
    Last Post: 11-23-2010, 10:01 PM
  3. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 05:12 PM
  4. Backhoe GC2410 Backhoe removal with jack?
    By bmarian in forum Massey Ferguson Owning/Operating
    Last Post: 06-28-2009, 09:39 AM
  5. Backhoe BX-23 Backhoe Cart
    By willjack in forum Kubota Owning/Operating
    Last Post: 01-08-2007, 09:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
