Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Elite Member foggy1111's Avatar
    Join Date
    Dec 2008
    Posts
    2,530
    Nisswa, MN
    JD 3320 eHydro w/ 300CX Loader
    Default 3320 OS Hydraulic Top Link fit
    I have been searching old posts to determine the set-up for a Hydraulic top link on my OS 3320.
    In the past I have read about a hydraulic "splitter" that plugs into the JD quick couplers and provides two hydraulic functions by just pressing a switch. It sounded as though this was not too expensive, was a "plug and play" installation, and would take care of my hydraulic needs.....which is to alternately run either my front grapple (I have those hoses on the tractor) and a hydraulic top link from my existing pair of JD quick couplers.
    Can somebody point me in the right direction or advise on this "splitter" set up? The proper name escapes me.
    Also, I am considering using 1/4" hoses for the top link and the front grapple to slow the operation(s). So far It looks like about 30" of hose for the top link. But I may wait for my top link to determine the length.....unless somebody has a good pic of a similar set up?
    I'm feeling a bit pesky with asking these questions.,....but I am laid up with a bad back and don't have the ability to go look for myself at the moment.....and I'm trying to get some plans accomplished during my "down time". Like ordering some parts online.
    My Markham / Gator grapple came in a week or so ago....and while I have briefly seen it.....it's driving me nuts to try and figure out the hydraulic hook-
    ups without getting my hands on stuff...exasperating.
    3320 eHydro, 300CX Loader & 15 + great attachments
    You gotta mine allot of dirt to find a diamond.
  2. #2
    Join Date
    Jul 2008
    Posts
    1,019
    Winterstown, PA
    JD 4200 & X475
    Default Re: 3320 OS Hydraulic Top Link fit
    The splitter's proper name is electric diverter.
    JD 4200 w/ 420 Loader, 8B Backhoe, 59" Snow Blower
    JD X475 w/ 54C Deck & 3-Bag Power Flow
    Looking for an engine out of a JD 4300/4310/4400/4410. Send a PM if you have one (or a parts tractor).
  3. #3
    Join Date
    Dec 2008
    Posts
    2,530
    Nisswa, MN
    Quote Originally Posted by arrabil View Post
    Thanks. I found some threads on a Fasse valve and electric diverter valve after my post above. If I got it pictured right.....I could use my 3rd function SCV valve to alternately operate two different cylinders (one for my grapple and one for top link).....while not altering the operation of my loader functions via the joystick.
    Price at Surplus Center is not too bad either.....like 150 for the valve.
    I wonder if the Fasse valve can be directly plumbed into the rear JD couplers
    at the current location? That would facilitate the use of my existing grapple hoses. The research continues.....and the plot thickens. Thanks for the heads up.
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by foggy1111 View Post
    Yes to all of the above
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    1/4" hose is perfect
    KennyD
    www.boltonhooks.com
  6. #6
    Join Date
    Dec 2008
    Posts
    2,530
    Nisswa, MN
    Thanks for confirming all the hydraulic connections Kenny. Hopefully this is going to cost lots less than what I thought it might. And...it should plumb together pretty cleanly. It's lots harder to imagine the connections when you don't have the tractor in front of you for reference.
    When I get it all connected together (and back in the game) I will take a few pics. I have not seen a thread on a JD 3X20 series plumbed like this.....YET!
  7. #7
    Silver Member deputy11's Avatar
    Join Date
    Feb 2010
    Posts
    143
    Nebr.
    JD3520cab
    1/4 hose is good and I used 24" lines for the HTL. Has worked extremely well.
  8. #8
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    Here are the instructions for the installation of the Electric diverter upgrade kit.
    Attached Files Attached Files
    Nuru
    JD 3520
  9. #9
    Join Date
    Dec 2008
    Posts
    2,530
    Nisswa, MN
    Quote Originally Posted by Nuru View Post
    While those instructions are interesting to read.....I don't think I am headed down that path. My install should be much simpler.....and cheaper.
    What I am contemplating is to use my existing 3rd function hydraulic outlets, which are already located on the rear of this tractor. I will "simply" plug an electric diverter valve to these outlets via my quick couplers. I believe Fasse (brand) originated this set-up ...but I see a similar diverter is available at Surplus Center. The one I am considering is #9-5117-A ...and it costs about $150.
    This diverter requires an electric switch....which will allow the selective use of either of two pairs of outlets....both of which can then be controlled by my existing JD 3rd function lever, adjacent to the joystick.
    I already have the JD hydraulic hose / line package on my loader which goes from my rear remotes to the front of the tractor. This will be my Primary hydraulics and it will use up one set of my outlets. The other set of outlets will go to my hydraulic top link.
    So in essence.....to change from using my grapple up front (primary)...to operating my hydraulic top link....I will simply flip an electric toggle switch to trigger a solenoid on the diverter valve......and proceed to operate the 3rd function lever to now operate the top link. Flip the switch again....and I'm back operating my grapple via the 3rd function lever.
    This is all starting to make sense....and its a pretty economical way to operate my needs for two remote cylinders...given what I already have installed on my tractor.
    However, I still have a concern about the cylinders being "in sync" with the valve. For example, what happens if your 3rd function lever setting for the front grapple is closed (and the cylinder is full open)....and the hydraulic top link is in the middle of its operating range.....and you flip the electric switch? What is going to happen?
  10. #10
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    Either the 9-5117A or the 9-7852 would be perfectly suitable.
    Nothing. The cylinder might "twitch" a little, but essentially nothing will happen. The ports that are not connected to the IN ports are blocked, so the cylinder will still hold it's position.
    KennyD
    www.boltonhooks.com
Similar Threads
  1. Princess Auto - Now Stock Hydraulic Top Link
    By Luremaker in forum Hydraulics
    Last Post: 07-18-2010, 08:20 PM
  2. Hydraulic Top Link Questions
    By sld in forum New Holland Owning/Operating
    Last Post: 06-11-2010, 07:29 PM
  3. Toplink Hydraulic top link w/built in valve???
    By gordon21 in forum Attachments
    Last Post: 06-11-2010, 05:06 PM
  4. Hydraulic Top Link for a Kubota BX2660
    By racolton in forum Hydraulics
    Last Post: 01-11-2010, 05:22 PM
  5. Pics of my M5040 HYP Top Link.
    By PSDStu in forum Kubota Owning/Operating
    Last Post: 07-14-2009, 07:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
