Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Aug 2009
    Posts
    49
    JD 4200, JD x360, JD z950r JD x739
    Default 3 pt keeps rising on my 4200
    I have a JD 4200. The problem is when I raise the 3 pt it keeps rising and works the engine. It use to stop rising when it got to the top of the travel.
    thanks yod67
  2. #2
    Gold Member
    Join Date
    Nov 2008
    Posts
    311
    minnesota
    JD
    Default Re: 3 pt keeps rising on my 4200
    probably needs adjustment in the linkage. Not familiar with that exact tractor but it sounds like it just thinks its supposed to go up a little more....shouldn't be hard to do.
    3520
  3. #3
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    I am also not familiar with the 4200, but I have gotten quite intimate with my 955 Mine has a rockshaft stop valve that is linked to the rockshaft that tells it to quit raising when it's at the top. The adjustment is simple... just loosen a jam nut and turn a turnbuckle. I would imagine that yours is similar.
  4. #4
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    Similar to what Mechanos said. Couple pages from 4200 manual attached.
    Attached Thumbnails Attached Thumbnails 3 pt keeps rising on  my 4200-4200-rockshaft-jpg   3 pt keeps rising on  my 4200-4200-rockshaft-feedback-jpg
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  5. #5
    Member
    Join Date
    Aug 2009
    Posts
    49
    So the problem is a lickage ajustment. I thought it might be a relief valve or a check valve problem.
    thanks yod67
  6. #6
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    When you move the three point control half way, does the hitch stop half way like it should? Or does it just keep raising?
  7. #7
    Member
    Join Date
    Aug 2009
    Posts
    49
    If the lever is in the raise position it travels all the way to the top and then it works the engine till I back off the lever. I can raise the 3 pt and stop the rising in the middle of the travel and it will stay in that position.
  8. #8
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    Quote Originally Posted by yod67 View Post
    That shows the feedback works, and I agree the problem is just the mechanical adjustment mentioned. Sounds like the relief valve is doing its job. Proper linkage adjustment will keep it from moving far enough to activate that valve.
  9. #9
    Member
    Join Date
    Aug 2009
    Posts
    49
    what actually does the relief valve do?
  10. #10
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    It relieves the system pressure when the rockshaft valve tries to keep extending the rockshaft piston after it reaches the end of it's stroke. If it didn't relieve the pressure.... something would go boom.
Similar Threads
  1. 3-Point Hitch Problem with JD 2520 3 pt hitch
    By GKQ in forum John Deere Owning/Operating
    Last Post: 07-10-2010, 12:50 AM
  2. 3 pt tiller
    By jimalsois in forum Private Party Ads Archive
    Last Post: 07-04-2010, 11:24 PM
  3. Transporting/lifting MMM w/ 3 pt
    By joseph143 in forum John Deere Owning/Operating
    Last Post: 05-13-2010, 04:45 PM
  4. Tiller 2 pt to 3 pt tiller hitch conversion
    By fjberres in forum Attachments
    Last Post: 04-08-2010, 11:40 PM
  5. 3-Point Hitch kubota b2410 3 pt too low
    By Wild Turkey in forum Kubota Owning/Operating
    Last Post: 04-05-2010, 11:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
