Results 1 to 6 of 6
  1. #1
    Join Date
    Dec 2008
    Posts
    50
    Northern Indiana
    John Deere 2320, 2520, 5303 and Farmall Super C
    Default 2320 Steering Wheel Removal
    I have tried without success to remove the steering wheel on my 2320. Does anyone have any ideas/tools to get this job done?
  2. #2
    Join Date
    Aug 2009
    Posts
    91
    SD
    Default Re: 2320 Steering Wheel Removal
    On my Dads X495 -same wheel, I sat on the seat and lifted with my hands and knees if you can imagine that, while he tapped the nut on the steering shaft. Of course you back the nut off flush with the threads first. Otherwise you'll have to find some pads for a gear puller?
    Tim
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    I am curious why you need to remove it?
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Join Date
    Dec 2008
    Posts
    50
    Northern Indiana
    I need to remove to to replace the instrument cluster. The tach froze up and destroyed the tach cable as well. An expensive fix!
  5. #5
    Join Date
    May 2007
    Posts
    846
    eastern PA-lower Poconos
    JD2320 w/R4 $21,100 w/7.16%off
    The JD2320 service manual says:
    1.Park machine with brake engaged
    2.Disengage three locking tabs at underside of steering wheel and remove steering wheel center cover
    3.Remove lock nut
    4.Remove steering wheel, if necessary use a suitable puller
    Eastern PA -JD2320 w/R4; 200CX w/61" bucket & Markham toothbar or JD adj forks; 46BH w/16", Imatch, ballast box & York rake-blade-scarifer, 54" front plow and trailer receiver. Case 580K w/fel+bh, mule 610XC
  6. #6
    Join Date
    Dec 2008
    Posts
    50
    Northern Indiana
    Well, I finally got the steering wheel off. I fabricated a puller and I don't believe I could have purchased one any better to do this job. The dang thing was on so tight it actually started to pull the steel bushing that is molded into the steering wheel started to pull out. Thankfully my puller was tight enough to the shaft that it popped it off. I was able to press the hub back where it belonged. On re-assembly, I coated all steel mating parts with anti-seize. I think my dealer was the last to work on the steering wheel and he just tightened it too tight.
    1952 Farmall Super C, 2005 JD 2320, 2008 JD 2520
    2008 JD 5303, 200CX FEL w/ 54" Bucket and 56" Manure fork, 54D MMM and 62D MMM
    Frontier RT1160 Tiller, JD LX4 Rotary Mower
    I-Match 3-Point hitch
    JD LX7, 7' Rotary Cutter, JD KBA 10' Wheel Disc
    54" Snow Blower, 54" Blade
Similar Threads
  1. 955 steering wheel removal
    By Mechanos in forum John Deere Owning/Operating
    Last Post: 08-15-2010, 01:11 PM
  2. Pulling a steering wheel on a Ford 3000
    By 73Ford3000 in forum New Holland Owning/Operating
    Last Post: 05-11-2009, 07:59 PM
  3. Replies: 0
    Last Post: 07-15-2005, 08:47 AM
  4. BX 2200 Power Steering
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 06-15-2003, 09:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
