Results 1 to 7 of 7
09-13-2010, 11:32 PM #1Member
- Join Date
- May 2010
- Posts
- 40
- Location
- Pennsville, N.J.
- Tractor
- J-D 2305
need parts(hose) for 260 backhoe?
I have a new 2305 with 260 backhoe and no matter how i try to look it up it won' t let me. any links to an exploded view or list of hoses I damaged the hose to the most vunerable bucket cylinder. any help appreciated. thanx , crossy
It only costs money to get OUT of south Jersey.
09-14-2010, 05:38 AM #2
Re: need parts(hose) for 260 backhoe?
Can you be a little more descriptive of your problem? A blown hose can be removed and taken to any hydraulic shop to have one made...
When you say you can't hook it up, do you mean the hydraulics or mounting the hoe?John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
09-14-2010, 10:16 AM #3Member
- Join Date
- May 2010
- Posts
- 40
- Location
- Pennsville, N.J.
- Tractor
- J-D 2305
When you say you can't hook it up, do you mean the hydraulics or mounting the hoe?[/QUOTE]
LOL- i said LOOK it up not hook it up. I'm just trying to find an exploded view.
Yes i'm aware i could run around and get a new one made, Pennsville is not exactly a 'hub' like westminster is. If i have to get one made i am going to put a coupling in the middle (inside the arm) so it is not one continuous piece.
but i want an exploded parts view for reference. i can print it all up at work. The way i have been using this thing (hoe) I will need more parts in the future. I even tried looking it up by the factory part number on my invoice.
thanx , crossyIt only costs money to get OUT of south Jersey.
09-14-2010, 10:27 AM #4Platinum Member
- Join Date
- Aug 2009
- Posts
- 860
- Location
- Kansas
- Tractor
- John Deere 755 purchased new in 1993
Are you logged into JD Parts? If you are then this link should work. A picture of it is attached.
John Deere - Parts CatalogJD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
09-14-2010, 12:14 PM #5Member
- Join Date
- May 2010
- Posts
- 40
- Location
- Pennsville, N.J.
- Tractor
- J-D 2305
that's the one i needed pal- that's where i found all the parts for my F525 front mower and went to the dealer with all the part numbers in hand. I just couldn't find it again. Thanx, crossy
09-14-2010, 05:03 PM #6
Sorry about the bad info earlier...I was replying from my phone to try to get you an answer quickly. There is a little tutorial linked in my signature for jdparts if you need help with it.
Look in the phone book under "hydraulics", there are little shops everywhere...John Deere 4110HST
09-14-2010, 07:32 PM #7Member
- Join Date
- May 2010
- Posts
- 40
- Location
- Pennsville, N.J.
- Tractor
- J-D 2305
I went into our auto shop at work and found we have a hose maker, BUT none of my style fittings. one guy recommended EXCEL in Swedesboro, NJ and they hooked me up while i waited. $62. not bad for a 107" long hose . I should have had him make it in two pieces with coupling in middle .
I already bought an aftermarket trans fan guard and a trans filter guard,. I think it's time for ME to develop a Cylinder hose fitting guard. the top one looks easy the bottom one not so.
thanx for the help , crossyIt only costs money to get OUT of south Jersey.
Similar Threads
Backhoe Anyone ever use a CUT mounted backhoe to dig a foundation?
By Lt CHEG in forum AttachmentsReplies: 33Last Post: 11-23-2010, 09:01 PM -
Backhoe 12" versus 16" Backhoe Bucket Size
By Don_Curley in forum Kubota Owning/OperatingReplies: 18Last Post: 07-27-2009, 04:12 PM -
Backhoe GC2410 Backhoe removal with jack?
By bmarian in forum Massey Ferguson Owning/OperatingReplies: 17Last Post: 06-28-2009, 08:39 AM -
Backhoe Can a BX2660 Be Fit w/ a Backhoe Later... like the BX25?
By robertm in forum Kubota Owning/OperatingReplies: 7Last Post: 05-27-2009, 09:13 AM -
Backhoe BX-23 Backhoe Cart
By willjack in forum Kubota Owning/OperatingReplies: 7Last Post: 01-08-2007, 08:13 PM
