Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    1
    1984 John Deere 750
    Default Selective Control Valve
    The SCV for my JD 750 loader has two handles - lift and bucket tilt. I think the SCV cylinder for the lift handle is leaking across its ports because the loader unexpectedly lifts all by itself without pulling the handle. JD wants over $650 for a new SCV (part number PC1873 70-30 or AM197083) and they don't sell any rebuild parts. Does anyone have any ideas on how to fix this? I've removed the SCV and it looks unserviceable. The exposed back end of the piston is round - there are no flats to get a wrench on.
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Selective Control Valve
    Welcome to TBN
    Your setup looks like the picture below correct?
    I think your best bet is to convert to a new joystick valve, get rid of the hard-lines, mount the new valve in a convenient location, then feed it with hoses.
    You can probably do it for about $350, and you will have a modern style valve.
    This would be a nice valve: https://www.surpluscenter.com/item.a...=1&item=9-7401
    Attached Thumbnails Attached Thumbnails Selective Control Valve-750-gif
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    New Member
    Join Date
    Jul 2012
    Posts
    1
    Canaan, ME
    JD 750
    I know this is an old thread but I also have the same problem that just started with my JD750- the bucket lifts on it's own and you have to hold the lever to bring it back down. I wondered if any of you have done the suggested conversion to the joystick valve, or if you found a way to repair the original valve? I like the idea of the conversion- but have one question- Would this also eliminate the pressure relief valve mounted on the loader arm and fed with hoses from the SCV valve?
    Quote Originally Posted by kennyd View Post
    Welcome to TBN
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,086
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    struell
    If current control valve spools are in neutral position but loader function moves on it's own accord the only "repair" is a completely new control valve.
  5. #5
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    You didn't say if your system is open or closed center hyd system.
    If the centering springs are weak or the nut loose on the spool end the spool could be sliding toward the lift side.
    Centering springs can be adjusted or replaced.
    If the spool is centering, there should be no fluid coming out the work port, and if there is fluid, then the spool is worn beyond use.
    If there is an external relief on the loader lift arms, it is there for extra protection. You may want that adjustable relief depending on the pressure rating of the cyl pressure verses the pump pressure..
    If your hyd system is CC, there is probably one relief valve close by the pump.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  6. #6
    Join Date
    Jan 2007
    Posts
    7,086
    Coyote Flats,Tx
    JD 750 is open center hyd's.
Similar Threads
  1. Replies: 196
    Last Post: 09-20-2009, 09:09 AM
  2. Hydraulic valve for grapple... what one?
    By 2310 guy in forum Hydraulics
    Last Post: 06-26-2007, 06:18 PM
  3. Solenoid motor control valve
    By m7040 in forum Kubota Owning/Operating
    Last Post: 04-24-2007, 09:18 PM
  4. Grease fitting on LA302 control valve
    By texblonigan in forum Kubota Owning/Operating
    Last Post: 04-24-2002, 02:10 PM
  5. John Deere selective control valve question
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-12-2002, 11:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
