Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    4
    jd 855
    Default JD 855
    My 855 has a Yanmar 3tn75rj.Am having trouble finding an exact replacement and JD wants 5K. What else will fit fairly easily? Thanks for your help.Jeff
  2. #2
    Join Date
    Feb 2009
    Posts
    86
    Central Texas
    Default Re: JD 855
    You might already know; the 3TN75RJ was also used in the F1145 commercial mower.
    Is your current engine re-buildable? Engine kits are readily available.
  3. #3
    New Member
    Join Date
    Oct 2010
    Posts
    4
    jd 855
    Default Re: JD 855
    Rod through block so its dead.Looking for info if another 3TN will be close to the same and can make work.Found a 3tne84.Looks close.May try it.
  4. #4
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: JD 855
    Dont see why it wouldn't fit. That's the engine used in the 955 which pretty much shares all the dimensions of the 855 (in regards to the engine compartment). I have a 3TNE88 in my 955 and it fits like a glove.
    BTW... does your 855 have the fuel tank in front of the radiator? Or is it between the engine and operator's station?
  5. #5
    Join Date
    Feb 2009
    Posts
    86
    Central Texas
    Default Re: JD 855
    The 3TN84 from a 955 should be close, although it's not identical. (Water pump, cooling fan, oil cooler, etc). It's also indirect injection as opposed to the direct injection of the 3TN75.
    Mechanos brought up the fuel tank location. This may be a concern, you'll have to do more re-plumbing/fabrication if your 855 is an earlier model with the fuel tank in front of the radiator. All 955's had the tank between the operators station and engine.
    I've never heard of the 3TNE88.
    Let us know how it works out.
  6. #6
    Join Date
    Jan 2002
    Posts
    1,501
    Lancaster PA
    Yanmar 186D
  7. #7
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    Default Re: JD 855
    Quote Originally Posted by twarr1 View Post
    The 3TN84 in the 955 is direct injection. The 3TNE88 was used in the 4400 and 4410.
    Attached Thumbnails Attached Thumbnails JD 855-955-injection-jpg   JD 855-3tn88-jpg   JD 855-3tn88-4310-jpg
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  8. #8
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: JD 855
    Not sure what my 3TNE88 came out of.... it's a non-JD engine. According to it's data plate, it is rated at 37hp. It was in the tractor when I bought it.
  9. #9
    Join Date
    Feb 2009
    Posts
    86
    Central Texas
    Default Re: JD 855
    Quote Originally Posted by JD755 View Post
    I stand corrected.
  10. #10
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,661
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Default Re: JD 855
    Quote Originally Posted by acelr8 View Post
    JD has an engine for sale? Even when I rebuilt my last 955 engine 5 y
    ago, it was out of production, and the only units available were stashed
    in some dealer's warehouse. (I did find one for sale for $5400 BTW.)
    The neat thing about the x55s is there is no foot clutch, so the bellhousing
    does not bolt up to the HST or gearbox. You have a simple drive shaft
    with rubber coupling, and the engine sits on top of a frame. Engine
    swaps should be much easier than on other tractors.
    Of course, almost all blown engines are rebuildable.
Similar Threads
  1. Maintenance on newly bought JD 855
    By dsmau in forum John Deere Owning/Operating
    Last Post: 08-27-2009, 10:22 PM
  2. Looking for a JD 855 Graveyard
    By 855Idiot in forum John Deere Owning/Operating
    Last Post: 06-01-2008, 10:05 PM
  3. JD 855 Front End Loader
    By Striker4972 in forum John Deere Owning/Operating
    Last Post: 05-15-2008, 01:45 AM
  4. JD 855 Rear wheel dragging.
    Last Post: 02-11-2008, 07:42 PM
  5. Installing 72" MMM on 855 JD
    By rgsmitty in forum John Deere Owning/Operating
    Last Post: 09-26-2006, 10:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
