Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    New Member MGB2720's Avatar
    Join Date
    Feb 2010
    Posts
    16
    Grand Falls, NB, Canada
    John Deere 2720
    Default Interior and exterior pics of Jodale Perry cab on 2720
    Some of you wanted to see interior pics of a Jodale Perry cab. Well I did the best I could using a smart phone...
    The noise level in the cab is not that bad. It does come with carpet like material that is applied to the fenders on the inside as well as under the seat. There is also a rubber type membrane that is installed on the floor. I am very pleased with it.
    The only negative (probably applies only to me) is that I cannot hear anymore if my spreader is out of salt and grit. I have to look around if it is still spreading material.
    Attached Thumbnails Attached Thumbnails Interior and exterior pics of Jodale Perry cab on 2720-2720-8.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-14.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-15.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-16.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-17.jpg
  2. #2
    Join Date
    Feb 2010
    Posts
    16
    John Deere 2720
    Default Re: Interior and exterior pics of Jodale Perry cab on 2720
    Here are more exterior pics taken this morning.
    I blowed some snow last night in my t-shirt... fan setting on low...
    I had mentioned in a previous thread that I was still getting used to the cab. I live on a hill side and as you can see from the pics, I need to spread salt and grits up the hill otherwise vehicles wouldn't be able to drive up the hill or safely drive down. I also have a pair of Norse chains on my 2720. Believe me they are required!
    The blower is a bit undersized for this tractor. I had purchased it for a 2320 that I used to own. Notice that I added wings to the blower to get the added width.
    Attached Thumbnails Attached Thumbnails Interior and exterior pics of Jodale Perry cab on 2720-2720-7.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-11.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-12.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-13.jpg   Interior and exterior pics of Jodale Perry cab on 2720-2720-19.jpg
  3. #3
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    594
    Alabama PA
    Which one?
    Does that cab replace your ROPS? Does it add much to the total height?
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  4. #4
    Join Date
    Feb 2010
    Posts
    16
    John Deere 2720
    Yes it does replace the rops. My tractor with Jodale Perry cab is about 84" in height.
  5. #5
    Join Date
    Nov 2007
    Posts
    594
    Alabama PA
    Which one?
    Thanks. I've pondered a cab for my machine and that is a concern.
    JD855 w/stuff.
  6. #6
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Thanks for the interior pics. Are you going to get a cloth seat cover so you don't get the frozen or scorched butt depending on the time of year?
    Here is the link to the OP's original cab post. http://www.tractorbynet.com/forums/j...perry-cab.html
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  7. #7
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,796
    Central New Hampshire
    Kubota B3030HSDC
    What a nice looking cab JoDale Perry makes. Looks about as good as anything the factory would come out with.
  8. #8
    Gold Member
    Join Date
    Apr 2002
    Posts
    465
    SE Minnesota
    John Deere 4720 Cab
    I like those tire chains. Who makes them and what did they cost? Thanks
  9. #9
    Gold Member fdmars's Avatar
    Join Date
    May 2009
    Posts
    260
    Central CT
    John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
    No THAT is a snow fighting machine....Looks great
    200CX Loader, 47" Snowblower, 54" Deck, PowerHorse 3ph 13 ton logsplitter
  10. #10
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    592
    Northern N.B.
    2008 2305 jd
    You are going to love that cab, believe me. Making the heater connection is fairly easy. Just follow the instruction. Electrical is also easy. I connected the red wire to the starter (live), ground to the motor mount, right beside the starter. The other wire was a little more tricky. I ran a wire from the key switch to the access door (bottom left near the brake pedal, rubber access plug) and I installed a wire connection. I did this because I remove my cab every summer so I use this access door to get to the wire. Connecting the wire to the accessories on the key switch prevent us from making the mistake of forgetting the heater fan or wiper on. On the other hand, the cab lights will work with or without the the key, switch on, accessories. Here's a couple of pic. (soft-cab)
    Attached Thumbnails Attached Thumbnails Interior and exterior pics of Jodale Perry cab on 2720-dscf5805.jpg   Interior and exterior pics of Jodale Perry cab on 2720-dscf5818.jpg
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
