Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Silver Member MikeyB's Avatar
    Join Date
    Oct 2006
    Posts
    134
    Parker,CO
    JD 3320
    Default 3320 Tilt Cylinder
    I will soon have (hopefully) two hydraulic outputs on the rear of my 3320.
    I already have a top link cylinder that I bought for a song from my local dealer when another customer bought the entire top-n-tilt kit and only wanted the tilt cylinder.
    After looking at JD parts I was pretty astonished at the price they wanted just for the tilt cylinder $450, and another $105 for the clevis that goes from the lower 3 pt arm to the cylinder rod. I will be pricing the entire kit from the dealer. Sometimes it seems the kit is way cheaper than buying parts piecemeal.
    My question is has anyone figured out a different cylinder that will work for the tilt? It looks pretty specialized having a spherical eye mount at the top and looks like a keyed shaft at the bottom with a set screw for the clevis.
    Thanks,
    Mike
    Attached Thumbnails Attached Thumbnails 3320 Tilt Cylinder-mp35388________un25oct04-gif
    JD 3320 w/300CX Loader, LX5 Mower, Landpride 3584 Backblade, Frontier SB1164, Rear SCV
    '04 KTM 300 EXC (Awesome!), '09 Harley FLHTC
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,912
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: 3320 Tilt Cylinder
    CCM will make you one with a DPOCV for $250. Give them a call. Do a search on "ccm" and "dpocv" for lots of reading
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,316
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    I have a question for you. Do you think that the slot in the clevis is needed? I don't see why you would even want that. Can you or anyone else that has a John Deere elaborate on this and what it accomplishes?
    Like Kennyd said, you can get a custom Hydraulic side link for $250, but I don't know if it will have that slot or if you even want or need that slot. My thinking is that you would not want the slot that the OEM clevis has.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  4. #4
    Join Date
    Oct 2006
    Posts
    134
    Parker,CO
    JD 3320
    Quote Originally Posted by MtnViewRanch View Post
    Haven't looked at my hitch in a while. Too lazy to walk out to the shop right now.. But IIRC the clevis on there at present is angled. That is my main worry. I'll have to take a look at it tomorrow. The slot might be helpful in the overdoing it department which I am prone to do. I can only think it provides a little relief if you try to give it too much down pressure. Don't know for sure.
    Mike
  5. #5
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,316
    Quote Originally Posted by MikeyB View Post
    Mike
    Even with a hydraulic side link, you still will not have any down pressure. You only get to adjust the tilt of your implement, the implement still only has the weight of the hitch and implement for any cutting ability.
    Maybe tomorrow you can check out that clevis and be sure of how much of an angle it is. For some reason I was thinking that it is not much if any at all.
    Brian
  6. #6
    Gold Member Cocre's Avatar
    Join Date
    Aug 2008
    Posts
    424
    Sandy Run, SC
    '06 John Deere 3320
    On my 3320 the side link has a swivel eye on the top end and a straight clevis on the lower end. When I made my hydraulic side link I cut the ends off of an appropriate hydraulic cylinder, welded the swivel eye off of a generic top link to one end and fabricated a clevis and welded it to the other end. No slot, just a hole. The slot is designed to allow the implement to float a bit by allowing an angle change rather than lifting the entire device when a slight rise on one side is encountered.
    '06 John Deere 3320
  7. #7
    Join Date
    Oct 2006
    Posts
    134
    Parker,CO
    JD 3320
    Quote Originally Posted by Cocre View Post
    Thanks Cocre,
    Do you have a check valve installed on the cylinder or just called it good
    with the hydraulic pressure holding the cylinder in position? It looks like whatever I do, the cylinder will need some customization to work since it has
    different end attachments.
    Thanks again,
    Mike
  8. #8
    Join Date
    Aug 2008
    Posts
    424
    Sandy Run, SC
    '06 John Deere 3320
    Thanks Cocre,
    Thanks again,
    Mike
    I installed a flow control valve in one of the lines going to the tilt cylinder. I use it to slow down the operation of the cylinder or to lock it in place.
    '06 John Deere 3320
  9. #9
    Join Date
    Jul 2003
    Posts
    12,912
    Westminster, MD
    He means the DPOCV that CCM has on their cylinders.
    KennyD
    www.boltonhooks.com
  10. #10
    Join Date
    Aug 2008
    Posts
    424
    Sandy Run, SC
    '06 John Deere 3320
    Quote Originally Posted by kennyd View Post
    Yeah, I understood that, but his question to me concerned holding the cylinder in position so I responded as to how I accomplished that.
    I installed the flow control valve to control the maximum ram speed, but I also use it to lock the cylinder in place similar to the DPOCV. It's not automatic, it's not located at the cylinder, and it's not a DPOCV, but it locks the cylinder solid. On my setup it is easy to get to and operate, and the additional function cost no more since zero flow is part of the range of this particular control valve. It is probably no more than an eight of a turn from where I like the flow to dead locked.
    In the end I can't say that I saved a bunch of money making my own tilt cylinder, but I had fun doing it and that counts for a lot to me.
    '06 John Deere 3320
Similar Threads
  1. Tilt Dump Cylinder Saga
    By woodlandfarms in forum Power Trac
    Last Post: 08-01-2010, 06:26 PM
  2. Advise on cylinder size for bucket tilt?
    By unioncreek in forum Hydraulics
    Last Post: 01-12-2009, 09:55 PM
  3. help finding a fel bucket tilt cylinder
    By tedder in forum Hydraulics
    Last Post: 11-30-2008, 01:34 PM
  4. anyone here with a hydraulic 3pt tilt cylinder???
    By leeinmemphis in forum Attachments
    Last Post: 10-18-2006, 12:50 PM
  5. Loader Leakdown
    By Matt4200 in forum John Deere Owning/Operating
    Last Post: 07-27-2002, 11:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
