prairiecannon
I posted a few weeks ago wondering if anyone had suggestions on installing a Berco soft cab on a 2305, primarily because the directions assume metal footrests and a slightly smaller frame than the 2305. The Berco unit is a "universal" type so was fairly adaptable and I am including some photos of the installation.
I swung the rear support posts (which attach to the rear hitch plate) to the side, which meant the rear vertical supports would be in front of the ROPS - this was necessary because the tractor has about an inch of clearance above the ROPS when entering the garage, and this way I could control the height of the cab to be below the ROPS. I have a couple of inches clearance above the rear tires.
I also used a couple of thin perforated nail plates to anchor bolts on the top side of the foot rests and bolted the front supports on the lower side.
The installation went fairly smoothly and I made the first run at sanding a steep driveway hill yesterday in relative comfort with a 20 mph wind blowing and a wind chill in the single digits.
