PILOON, I have place these picture to help identified the parts and location for Beenthere and maybe help bellygunner at the same time. The pic. you see were taken last year. If you look closely in the second picture, you can see a broken lock collar. I had it fix last year on the warranty. They said it was cause by a bend sprocket shaft. They replace the shaft but now I notice that the larger sprocket is wobbling, so they want to have a look at it and determent if it was not damage last year by the old sprocket shaft.
Deadman
Re: replacing sprockets and chain
My JD 47 inch blower has that exact same WOBBLE. I tried to tighten the chain last night, but as you rotate it, the slack changes. The owners manual says to tighten chain, and then rotate the auger to make sure there are NO TIGHT SPOTS. So, JD must know the auger wobbles!
Is this movement normal, or do you guys think I have a problem? My blower maybe has 3-5 hrs on it!
Thanks
Deadman, hopefully, I will have an answer for you tomorrow. Going to my dealer with the parts and will see what they say.
kennyd
You can't copy&paste...I right click the image, then save it to my desktop (so I can find it easliy), then attach the save image to the po
Thanks Kenny. I knew you would rise up to the challenge once again.:thumbsup:
Bellygunner, keep us up to date and put some pic. if you can. Good luck.
Henri
