Results 1 to 6 of 6
  1. #1
    Silver Member meb9796's Avatar
    Join Date
    Jan 2008
    Posts
    106
    VA
    JD 2305
    Default 2305 3pt hitch lifting weight?
    The specs say it can lift 1,100 lbs(approximate) at the lift arms and 650lbs (approximate) 24" from the lift arms. How much are you guys lifting out there? I've got a chipper that weighs over 400, a brush hog that has to weigh close to that, and a PHD that is also heavy but sticks out way behind the tractor. I'm trying to get a bigger chipper that weighs 800lbs and I'm wondering if the tractor will be able to move it?
    Thanx!
    JD3720
    300cx FEL
    7' Front blade
    woodmaxx 8" PTO chipper
    Leinbach 7200JR PHD with 12" auger
    Betst 60" EFG155 flail mower
    Bark Buster log splitter
    47" snow blower
  2. #2
    Gold Member BethesdaEC's Avatar
    Join Date
    Oct 2010
    Posts
    448
    Ellicott City, MD
    JD 2520
    Default Re: 2305 3pt hitch lifting weight?
    The 2505 has a limited CAT-1 hitch so on the lifting front I don't think that it will lift an 800 lbs splitter, and the other issue may be that vertical height. The 2305 is not capable of lifting many taller attachments.
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,010
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    Rated lift capacity for 2305 is 681 lbs 24" behind the link arms. 800 lb chipper has most of the weight toward the back. It might be able to lift it but will be close. The PHD is no issue. 400 lb bush hog should be ok. You will need front end weights unless it has a FEL.
  4. #4
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Time for a bigger tractor.
    You have a great excuse or three.
  5. #5
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,092
    Westminster, MD
    John Deere 4110
    Lifting is only part of the problem as I read...Will you have the HP to effectivley run a bigger chipper?
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  6. #6
    LD1
    LD1 is online now
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,478
    Central Ohio
    Kubota l3400
    Even if it will lift it, you will be stressing everything to the MAX. Including the engine because it probabally requires a lot of HP. I personally wouldn't want to do it on a regular basis as longevity will probabally suffer a lot.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
Similar Threads
  1. Weight distributing hitch bars question
    By hrcarver in forum Trailers & Transportation
    Last Post: 10-01-2010, 07:36 PM
  2. Replies: 14
    Last Post: 01-03-2010, 10:20 AM
  3. Here's my 3pt Reese hitch adapter (Handy Hitch)
    By kebo in forum Build-It Yourself
    Last Post: 10-23-2009, 09:58 PM
  4. Weight Distributing Hitch Questions and More
    By MossRoad in forum Trailers & Transportation
    Last Post: 05-11-2009, 07:58 PM
  5. Ballast DX29 - 3pt hitch weight
    By shiggy in forum Case-IH
    Last Post: 12-30-2006, 10:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
