bud4410
- Joined
- Oct 24, 2004
- Messages
- 112
- Location
- kingsville, maryland
- Tractor
- jd 3520 HST open station turf tires air seat jd 997 ztrak 72"
i am setting up my 366 blade on my 3520 for the first time. i clear a blacktop drive. do you set it so it rides on the two feet with the edge of the blade about 1/2" off the pavement? how about the top link? top hole or bottom? i can lengthen the link to rock it forward on the feet to get the blade closer or shorten to raise it. the feet are pitched forward. does this sound correct? do you put the bolts in the u shaped brackets on the long arms in the top holes to let it ride up & down in the U or in the bottom holes to use the float off of the hyd cyl? you guys with the new front hitch & 366 blade please give me your thoughts. thanks in advance.............bud
