Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Member
    Join Date
    Dec 2010
    Posts
    27
    Default 2940 Hydraulic issue
    We have a 2940 4WD that is having an issue. Went to dump the bucket the other day and the boom was raised about half way and I lost all hydraulics to the bucket and 3pt hitch and steering as soon as the bucket was fully dumped. . Changed the oil and filter, and everything seemed to work ok, then tonight it did the exact same thing, at the same time (when bucket was fully dumped). I have very partial hydraulics this time. If I flip the high/lo selector it makes the hydraulics almost stop. Any assistance? The clutch is starting to go so I know we have a tractor split in the future. Just don't want to do it until summer.
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,839
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: 2940 Hydraulic issue
    It may have an internal Hydraulic leak in your HI-LO bleeding off pressure.
  3. #3
    Member
    Join Date
    Dec 2010
    Posts
    27
    Whats the best way to go about testing this?
  4. #4
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,213
    texas
    7040 HDC 1153 fel
    if its not a bleeding off issue then your hydro pump is going out.an if its what im thinking youll have overhaul the hydro pump.an make sure not to pinch any seals or youll be overhauling it again.
  5. #5
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    How long did it work OK after you changed the filter? Also, does the clutch slippage seem worse in Hi or Low? Or is it the same? Try turning pto on and off and test hydraulics in both positions. Have you checked the sump screen? It could be clogged with brake material. There are many possible reasons for your problem. If you can answer a few questions, we can point you in the right direction.
  6. #6
    Member
    Join Date
    Dec 2010
    Posts
    27
    Where is the sump screen? It worked ok for about a week after I changed the fluid, but it wasn't used for much during that week. I also find it wierd it happened when the bucket was fully dumped both times. I'm 100% sure but I think the clutch slippage is the same in hi and lo.
  7. #7
    Member
    Join Date
    Dec 2010
    Posts
    27
    Do you think the clutch slippage could be a hydraulic issue? We adjusted it and it doesn't slip as bad, although it still slips. When it started slipping it did it all of the sudden, not gradual at all.
  8. #8
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,237
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    The supply tubes on the hyd Hi-Lo & pto have been known to crack/leak. Testing with a gauge will help diagnose the problem. Does the loader have an ind control valve ie not scv operated? If so the valve could be the problem.
  9. #9
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    The sump screen is behind the filter in the side of the transmission housing. It is behind a large plug(maybe 2")that needs either a 1/2" breaker bar or a large allen wrench to remove. Just remove the plug and slide out the screen. It is about 10" long. The slippage could be a hydraulic issue, but since it seems to slip the same in hi or lo, probably not. Unless the sump screen is totally clogged.
  10. #10
    Member
    Join Date
    Dec 2010
    Posts
    27
    There is only one hydraulic filter in the whole system correct? Very possible the sump screen could be clogged as it has not been cleaned since we have had the tractor. (10 years or so)
Similar Threads
  1. Backhoe Hydraulic Issue
    By 2710Fan in forum Hydraulics
    Last Post: 07-06-2015, 06:17 PM
  2. Ever Clutch Follow up
    By clinter36 in forum Kubota Owning/Operating
    Last Post: 04-15-2014, 07:52 AM
  3. hydraulic fluid filter (strainer) issue
    By palomar in forum Kubota Owning/Operating
    Last Post: 08-11-2010, 10:40 AM
  4. Hydraulic issue...
    By mrcaptainbob in forum Hydraulics
    Last Post: 06-27-2006, 11:14 PM
  5. Hydraulic problems
    By EMail4U in forum Hydraulics
    Last Post: 10-02-2004, 08:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
