Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Oct 2004
    Posts
    8
    NE Nebraska
    JD 755 Front Wheel Assist
    Default JD 755 compact tractor won't stay running
    Moving snow for about 3 hours and my tractor just stopped running. Temp was about 3 degrees with maybe -15 wind chill. Running #1 diesel, haven't had any problems in colder temps. Any way, I could turn key and it would run for a brief period of time and then quit. I replaced the fuel filter and bled the lines, but not the lines that go into the injector. The fuel pump continued running after the tractor quit so I don't think that is the problem. One thing I noticed when it would quit, "bare with me I don't know my parts", there is this accordion looking thing with a rod going into the center of it that when it runs moves forward and when the engine quits it slides back. So I put my finger on the end of this plunger while it was running and held it there for awhile and it would not quit, but if I would remove my finger, the plunger would slide back and the engine would quit. What is this thing, does it have anything to do with the thermostat? Any suggestions?
    Doug
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: JD 755 compact tractor won't stay running
    Might be gelled fuel. What is the history of the diesel fuel that you are now running in the 755?
    Is the plunger shown in this pic? That in the pic is the fuel solenoid.
    It may be shutting the engine down as a result of some fault (problem).
    Attached Thumbnails Attached Thumbnails JD 755 compact tractor won't stay running-755_diesel.jpg
  3. #3
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    I have the CD tech manual for the 755, but it says nothing about the Yanmar diesel other than how to remove it.
    But I have a JD455 with the Yanmar diesel and the following is mentioned in troubleshooting.
    Also, from the 455 tech manual, is the following description of the operation. Might look at a seat switch or PTO switch on given the outside chance that is causing the fuel solenoid to shut the engine down.
    Attached Thumbnails Attached Thumbnails JD 755 compact tractor won't stay running-755_fuel_solenoid_troubleshoot.jpg   JD 755 compact tractor won't stay running-755_fuel_solenoid_operation.jpg
  4. #4
    New Member
    Join Date
    Oct 2004
    Posts
    8
    NE Nebraska
    The fuel is only a few days old. I added additive 911 to tank and to the fuel filter bowl when I changed filter. The ribbed rubber boot to the right of the arrow marked C is what I was refering to. Is that the fuel solenoid that you mentioned. What does it do?
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    Yes the fuel solenoid. See previous post for additional attachment. Hope this helps some.
  6. #6
    Platinum Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    That device with the plunger is the fuel shut-off solenoid. There are two coils in it. One coil that activates in the start position and then another coil activates to hold it open in the run position. It is not too uncommon for the solenoid to get weak over time and fail. Sure sounds like a failed solenoid to me.... with extended run time, the coil is getting warm and losing it's ability to stay open.
  7. #7
    New Member
    Join Date
    Oct 2004
    Posts
    8
    NE Nebraska
    Well, in the morning I'll be giving my JD dealer another call. Thanks for the info so far.
  8. #8
    Gold Member yankeerider's Avatar
    Join Date
    May 2007
    Posts
    418
    North Central Connecticut
    Deere 755
    Doug-
    Don't overlook the not-so-obvious. The fuel pickup on these machines can fall apart, causing you to run out of fuel with a half tank. First step is add a gallon of fuel if you can.
    Jerry
    JD 755 w/70 loader, 60" MMM, DR 3pt chipper, Woods RB60 blade, 48" KKII tiller, 8 hp tow behind Giant Vac
    Gator HPX 4x4 Gas,Cat 303c CR mini-ex
  9. #9
    New Member
    Join Date
    Oct 2004
    Posts
    8
    NE Nebraska
    Thanks for all the input. I got my tractor up and running. Didn't have to replace anything, think it was a bad connection, saved me $120. Back to moving snow.
Similar Threads
  1. international havester 254 wont stay running
    By jdug in forum Parts/Repairs
    Last Post: 08-29-2010, 02:44 PM
  2. JD 755 hydraulic top link
    By honda432 in forum Hydraulics
    Last Post: 01-05-2010, 05:55 PM
  3. JD 755 No Hydralics, PS or Drive
    By PlumbHUR in forum John Deere Owning/Operating
    Last Post: 12-11-2009, 10:11 AM
  4. My Sub Compact "TLB" Review (BX24, JD 2305, and MF GC2310)
    By Airic in forum Buying/Pricing/Comparisons
    Last Post: 03-06-2008, 11:03 AM
  5. JD 755 Hydro Neutral Switch
    By shoogg in forum John Deere Owning/Operating
    Last Post: 06-16-2007, 10:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
