2520 Snow mover
   / 2520 Snow mover #1
revitupfaster
Southern Ontario Canada
JD X495 & JD2520
I purchased my new 2520 in September. Previously I was using an X495 with the Front Quickhitch and JD 54" Blade for snow removal. I had to use chains on the X495, and was hoping to get away without chains with the new 2520.
With all the talk about the R4 Industrial tires not being all that good for snow removal, I was concerned about how they would work. The areas where I need to move snow are pretty flat, but nevertheless, I needed convincing. Based on suggestions from this forum, I did purchase a ballast box for added traction, which was definetely a wise investment. It sure does give much better traction.
Anyway, I no longer have any concerns about moving snow. For my purposes, this setup works great. I have posted a few pics, showing the snow we have at present. I have managed to pile up banks of over 5 feet, all with the blade.
I'm a happy camper, and no longer concerned about the R4's in the snow.
REV
   / 2520 Snow mover #2
Wow... That's one sweet setup!! I like how high you were able to pile that snow:thumbsup:
   / 2520 Snow mover #3
Great looking tractor...are the rears filled or just ballast box?
   / 2520 Snow mover
No, the rears are not filled. I want to be able to drop the weight off when I'm cutting grass. The ballast box is great for adding the weight only when you need it. It certainly does add traction. For a while this winter, I tried plowing without it, and it sure does make a difference with it on.
REV
   / 2520 Snow mover #5
Do you have to use tools to switch between blade and loader?
   / 2520 Snow mover
No tools necessary to switch back an forth. Takes only a few minutes to remove the blade, and a few more minutes to attach the loader. The thing that takes the longest is to switch out the hydraulic lines for each attachment, which again, is really just another 5 minutes or so.
REV
   / 2520 Snow mover #7
Hi Gittyup,
As REV says, it's not that big an operation.:thumbsup: You also need to make sure that your loader is on a level surface when you drive the machine back into it.
A friend told me that he made the mistake of pulling the loader off on a lawn, and had no end of trouble putting it back on. Likely due to alignment issues.
   / 2520 Snow mover #8
Your friend is correct...I can assure you he used many 4 letter words that day:thumbsup:
   / 2520 Snow mover #9
REV
That's a nice setup!!... It sure does a great job!! :thumbsup:
Hi Joe,
You have a nice setup also!!:thumbsup:.... Kenny done a great job on your plow!!
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
STORAGE FEES (A54313)
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55301)
Case Wheels for...
