Results 1 to 6 of 6
  1. #1
    Join Date
    May 2007
    Posts
    846
    eastern PA-lower Poconos
    JD2320 w/R4 $21,100 w/7.16%off
    Default How do I remove the fuel filter bowl locking ring?
    The JD2320 operators manual instructs me to turn it counterclockwise. But normally with a right hand thread it would be turned clockwise as seen from the top.
    I can't see any threads so that doesn't help. It's on too tight to turn by hand and a rubber strap wrench didn't work. I'm thinking that a oil filter wrench might be what I need.
    I need to be able to remove the filter if I get fuel gelling or paraffin precipitation.
    Eastern PA -JD2320 w/R4; 200CX w/61" bucket & Markham toothbar or JD adj forks; 46BH w/16", Imatch, ballast box & York rake-blade-scarifer, 54" front plow and trailer receiver. Case 580K w/fel+bh, mule 610XC
  2. #2
    Elite Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    3,589
    michigan
    jd 1070
    Default Re: How do I remove the fuel filter bowl locking ring?
    Ah, but it should be looked at from the bottom. That's the way the ring nut is threaded. It really shouldn't be very tight. Can you get a pipe wrench around the 'nut' while holding the bowl with your hand?
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
  3. #3
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,867
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Might help to see the parts breakdown. You are wanting to turn the ring off that secures the hanging filter bowl, and they are normal right-hand threads. Get a grip on the ring item 24 and push to the left.
    Attached Thumbnails Attached Thumbnails How do I remove the fuel filter bowl locking ring?-2320_fuelfilter-jpg
  4. #4
    Join Date
    Nov 2008
    Posts
    1,191
    Covington, GA
    JD 870
    Mine took a lot to break loose. I probably sprayed Triflow or Kroil on part 24, the lock collar in hopes that it might help unstick things. I may have removed the whole assembly from the tractor to get a better grip on the lock collar. I do not recall if I used a strap wrench or a pipe wrench to break it loose. It sure would be nice if someone sold a spud wrench/spanner, kind of like what you use to remove that nut that holds the agitator or drum in a top loader washing machine. It was/is right hand thread. Part 24 came loose with less stuggle a few years later. Either I did not overtorque, or it was less years so it did not corrode together as much.
  5. #5
    Gold Member
    Join Date
    Feb 2007
    Posts
    332
    Eastern Washington
    JD 2320
    It should not be on all that tight. Water pump pliers worked for me. Gave me a good feel and just broke it loose with them (turning to the left). Then just unscrewed the locking collar by hand. Going back together make sure everything is clean. I put on just a drop or two of diesel to lubricate and hand tightened until it seated and then another quarter turn. No problems since (10-12 hours or so).
    Ed
    JD 120, JD 2320, 200CX FEL, RB2060 Rear blade
  6. #6
    Elite Member RalphVa's Avatar
    Join Date
    Dec 2003
    Posts
    4,877
    Charlottesville, VA, USA
    JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
    The ring on my 4010 fuel filter was impossible to turn by almost anything that I had. What I ended up doing (and do it all the time now) is to remove the entire filter/bowl assembly from its mounting on the frame. There's a single 12 mm bolt holding it in place. Then it's easy to rotate the whole assembly on the flexible rubber lines to/from it to get at that silly ring.
    Ralph
    The natural gardener
    God's original intent
Similar Threads
  1. Kioti Filter and Manuals plus Dealer Recommendation for Parts
    By LeTempt in forum Kioti Owning/Operating
    Last Post: 08-25-2015, 10:14 AM
  2. Oil & Fuel Kubota Fuel Problem
    By ih574 in forum Kubota Owning/Operating
    Last Post: 11-12-2012, 02:58 PM
  3. Oil & Fuel how high should the fuel be in the filter bowl
    By kartingdad in forum New Holland Owning/Operating
    Last Post: 01-24-2011, 02:04 PM
  4. Bad fuel aftermath
    By farmgirlky in forum Kubota Owning/Operating
    Last Post: 08-23-2010, 08:40 PM
  5. Collaped Sediment Bowl
    By ericwill in forum Chinese Tractors
    Last Post: 09-16-2004, 01:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
