Results 1 to 9 of 9
02-21-2011, 07:03 PM #1New Member
- Join Date
- Dec 2009
- Posts
- 17
Frontier 1067 spreader non i-match
Okay gang. Found a Frontier 1067 on Kijiji, sorta like Craig's List. Guy says he never used it, comes with an agitator, for $650. Problem is that it is designed for i-match, which I don't have. I do know that the i-match option has to be ordered from the factory, when the spreader is ordered, bit I don't have i-match. Anyway to make this work with just the 3-pt hitch, by taking off a bracket, etc?
02-21-2011, 07:21 PM #2
Re: Frontier 1067 spreader non i-match
Just put it on like you dont have a iMatch, it will just take time and practice.
02-21-2011, 07:23 PM #3New Member
- Join Date
- Dec 2009
- Posts
- 17
Thanks, Ed, figured it couldn't be much, option is only $9 from deere.
02-21-2011, 07:34 PM #4Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
And as soon as you can swing it, consider treating yourself with an iMatch. Doubt you will regret it.
02-21-2011, 08:15 PM #5Veteran Member
- Join Date
- Mar 2009
- Posts
- 2,355
- Location
- Southwest,Florida
- Tractor
- Kubota L3400dt,John Deere gt235
[QUOTE=dellwas;2270700]Okay gang. Found a Frontier 1067 on Kijiji, sorta like Craig's List. Guy says he never used it, comes with an agitator, for $650.
Even though guy says its new how does it look ?Has it been outside long ? Make sure gates operating ok and are not rusty or prone to give valuable seed,fert,ect. leaks.My seed spreader sleeps inside in shop,well lubricated and clean.Make sure your getting the correct pto shaft with it.
Boone2 CHRONICLES 7 : 14
(KJV)
02-22-2011, 06:10 AM #6New Member
- Join Date
- Dec 2009
- Posts
- 17
02-22-2011, 06:11 AM #7New Member
- Join Date
- Dec 2009
- Posts
- 17
07-16-2011, 09:35 PM #8
Kind of a late question but what parts do you grease and or lube? $650 seems like a good price BTW.
Thanks
07-16-2011, 10:17 PM #9Veteran Member
- Join Date
- Mar 2009
- Posts
- 2,355
- Location
- Southwest,Florida
- Tractor
http://worksaver.com/Manuals/cs-series.pdf
SS gearbox should have grease fitting.
Also pto shaft u-joints.
$500 in top condition sounds better to me.Seen the ones (different brands of course)at local TSC stores sometimes what seems like forever sit outside and rust.
(KJV)
Similar Threads
Frontier box blade
By GreatWhitehunter in forum John Deere Buying/PricingReplies: 35Last Post: 08-07-2009, 09:45 PM -
Need a Frontier finish mower or spreader??
By Shawk in forum John Deere Buying/PricingReplies: 0Last Post: 12-29-2006, 11:15 PM -
Ag Lime Spreader
By Laminarman in forum Build-It YourselfReplies: 13Last Post: 09-07-2004, 08:45 PM -
Spreader Worried about the manure spreader
By mundamanu in forum AttachmentsReplies: 11Last Post: 08-03-2004, 10:05 AM -
Load Match
By BillyP in forum John Deere Owning/OperatingReplies: 1Last Post: 05-01-2004, 06:22 PM
