Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Silver Member NYBOB's Avatar
    Join Date
    Feb 2003
    Posts
    205
    Maine NY(Binghamton area)
    2007 JD 3720
    Default 3720 with Curtis Snowplow
    I have a 3720 with a 300CX loader with a 6 1/2 foot Curtis snowplow connected by skid steer QA. I have a gravel driveway and at times the plow catches and rolls under. I have tried playing with the skid shoes but never seem to get it right. I try using the float of the loader and that helps but does not stop it all the time. Yesterday I noticed the springs were loose. How tight should they be? I love the plow except for this issue. Not being an experienced plow person, makes it more challenging.
    Any advice would be appreciated.
    Thanks
    John Deere 3720, 300CX FEL, Woods PRD7200 Finish Mower, 78" Curtis Snow Plow, Split-Fire 3PH wood splitter, -- John Deere X540, 54 in. Mulching Mower
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,725
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: 3720 with Curtis Snowplow
    The "roll forward" is designed to protect from something breaking. Additional pair of springs will help, but you have to weigh the risk that something will break with that extra load.
    Some have added a different edge to the blade, such as a hard plastic tube (pipe) so the blade cannot dig in and bite.
    You may look at the angle the blade is with the ground. A pic from the side could help us make some recommendations. If the pitch is off, and the FEL arms not low enough, then you may be pushing the blade into the ground rather than along the ground.
    Pics please.
  3. #3
    Join Date
    Feb 2003
    Posts
    205
    2007 JD 3720
    Quote Originally Posted by beenthere View Post
    Pics please.
    Thanks...I will get pictures ASAP. I will get two sets, one with the shoes all the way down as I have it now, versus the normal position I have them in. The pipe idea is an interesting one.
  4. #4
    Elite Member Duffster's Avatar
    Join Date
    Mar 2009
    Posts
    4,372
    Wisconsin
    Quote Originally Posted by NYBOB View Post
    Thanks
    How many springs does it have?
    Typically you should be able to stick a card between the wraps of the springs. You do NOT want them to tight.
    "If everyone is thinking alike, someone isn't thinking." George Patton
  5. #5
    Veteran Member Gizmo2's Avatar
    Join Date
    Jul 2006
    Posts
    1,918
    New York
    JD 2320
    Quote Originally Posted by Duffster View Post
    I would also check the attack angle, especially it the blade in mounted on the loader arms. Per beenthere's statement pushing the blade into the ground I would assume to be a pretty common problem with loader mounted blades.
    I will also add, especially with JD tractors where the loader arms are so short.
    JD 2320, 200CX FEL/61" bucket , 46 BH/16" bucket, FEL Forks, 72" Snow Blade, Landscape Rake, Ballast Box, PHD, The Wife
  6. #6
    Join Date
    Mar 2009
    Posts
    4,372
    Wisconsin
    Quote Originally Posted by Gizmo2 View Post
    I would also check the attack angle, especially it the blade in mounted on the loader arms. Per beenthere's statement pushing the blade into the ground I would assume to be a pretty common problem with loaded mounted blades.
    It is just the nature of the Curtis beast. It has an agressive attack angle which is great in many applications but not so great on gravel.
  7. #7
    Join Date
    Feb 2003
    Posts
    205
    2007 JD 3720
    It has 4 springs....
  8. #8
    Join Date
    Feb 2003
    Posts
    205
    2007 JD 3720
    Here are the pictures requested.....I hope they show what you need to see.
    Attached Thumbnails Attached Thumbnails 3720 with Curtis Snowplow-snowplow-side-view-jpg   3720 with Curtis Snowplow-snowplow-springs-jpg
  9. #9
    Elite Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    2,617
    Upstate NY
    JD X585
    Bob,
    you have a lot of control from the seat of how aggressive
    the blade is.
    depending on how low your shoes are, you should be able to control
    the angle of the blade with the curl function of your loader.
    use the shoes as a pivot point, and by using the curl up or
    down you can push that cutting edge down closer to or
    into the dirt. (theoretically)
    a soft base, not frozen, will wreak havoc no matter what you
    do. we had warm days and inches of rain this past weekend before
    our 2' of snow, so all the snow that fell in the early part of the storm
    landed on warm wet ground and made it quite challenging for everybody
    to move. it was basically slush at the ground with 2' of snow on top!
    i would imagine you want the springs somewhat tight, so they need a bit
    of pressure before the blade trips. but you really want the edge gliding along
    just above the gravel so it doesn't, a tricky feat that will come with experience.
    many blades have a lock feature that allows you to make the blade
    rigid, like for dirt work, i can't remember off hand if the curtis has that
    or not. you can look and see if there is a pin or holes for a pin that would
    do that. keep in mind with it rigid, it's gonna bite, and bite hard if you do
    end up into the gravel.
    keep us posted on your progress, lots of good info here at TBN!
  10. #10
    Join Date
    Feb 2003
    Posts
    205
    2007 JD 3720
    Pics please.
    Are there any pictures available or instructions on how to mount a tube on the blade edge? I would like to see if that would work also.
    Thanks
Similar Threads
  1. Curtis Snowplow
    By jgbanshee in forum New Holland Buying/Pricing
    Last Post: 03-15-2009, 10:21 AM
  2. Curtis snowplow & mount for Kubota RTV 900
    By coobie in forum ATVs & Utility Vehicles
    Last Post: 07-21-2008, 05:58 AM
  3. Curtis snowplow & BX2200
    By MikeCT in forum Kubota Buying/Pricing
    Last Post: 03-10-2002, 08:35 PM
  4. Curtis Snowplow
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 12-04-2001, 04:15 PM
  5. Curtis Snowplow
    Last Post: 11-03-2001, 07:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
