Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default 2210 vs 4010 which is better? Any Common Problems with them?
    HI All,
    I have been looking for the past couple month for a tractor.
    I have narrowed it down to just 4 models, but I think I will be ending up with one of these two tractors (2210 or 4010).
    Any opinions on the 2210 vs 4010 in terms of with would be a better tractor?
    I would be getting it with a MMM and a FEL.
    Has anyone heard, seen, or experienced any common problems with the JD 2210 and 4010.
    Thanks in Advance.
    Fran
  2. #2
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Re: 2210 vs 4010 which is better? Any Common Problems with them?
    Subvet,
    See my reply to your post under the general forum "Buying and Pricing".
    It's just my $.02.
    Bob
  3. #3
    Join Date
    Jan 2003
    Posts
    13
    PA
    John Deere 4010
    I can not tell you to much about the 2210 but I can tell you that I am real satisfied with my 4010 (80 hrs) This machine has done plenty more for me than what I expected it to do! I did look at the the 2210 after I purchased my unit & thought that it looked more like an oversized garden tractor. Again, I can not say enough good things about my 4010! I have about 4 acres & have been using it to clear the majority of the trees off the land, move dirt, remove stumps & numerous other operations. I have used this machine extremely hard in the last 4 months, I have dented both fenders, had a tree fall on the hood (I bailed off or it would have got me) & broke both rear lights. This tractor has performed without a glitch! I will be happy to answer any specific questions you have! I do not think you will go wrong with any of the the tractors, after all they are both green! Good Luck!
  4. #4
    Join Date
    Aug 2002
    Posts
    108
    Derry , NH
    2002 JD4110 HST
    SubVet ,
    I have been happy with my 4110 410 FEL filled R4's with about 30hrs so far. I remember going into the dealer shortly after the 2210 came out , and for a few dollars more then the 2210 you could get into a 4010. Get the most tracotor for your money.
    Good Luck ...
    Mark
  5. #5
    Veteran Member JDGREEN4ME's Avatar
    Join Date
    Sep 2002
    Posts
    2,248
    Southeast PA
    John Deere 2520, John Deere X534, LT150, STX 38
    I am also happy with my 4110, have a little over 20 hours on it now...
  6. #6
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    Go with the biggest you can afford - the 4010!
  7. #7
    Join Date
    Jul 2002
    Posts
    241
    West Michigan
    JD 790, Steiner 230, IH 340U, Farmall Super C, Farmall C, IH Cub Cadet, Wheel Horse 8.75
    The J.D. 2210 has a bigger engine an more HP then the J.D 4010,
    The physical size/weight between the tractors is close but the
    2210 has smaller tires...
    J.D 4110 is also similar in size but heavier with larger tires plus
    a few extras...
    J.D 4010, 47 cu.in., 18.5 eng. HP, 14 PTO HP @ 3000 RPM
    J.D 2210 61 cu.in., 22.5 eng. HP, 18 PTO HP @ 3000 RPM.
    J.D 4110 61 cu.in., 20 eng. HP, 17 PTO HP @ 2600 RPM
    Done from memory which is not always 100% accurate...
    Richard...
  8. #8
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    I think the 4110 has 25 hp and 20 PTO
  9. #9
    New Member
    Join Date
    Sep 2005
    Posts
    0
    <font color=green>I think the 4110 has 25 hp and 20 PTO<font color=green>
    <font color=black>In my JD Literature the 4110 is 20 hp @ 2650 rpm, 17 PTO hp &amp; 61.02 cu. in.<font color=black>
  10. #10
    Join Date
    Oct 2002
    Posts
    68
    Missouri
    JD 2210
    I was faced with the decision to get a used 4100 or a new 2210. Both about the same price. I went with the 2210 because of one word, warranty. Hp is all relative - you want to compare something, look at loader specs. The 4100 series will win, but the 2210 is a sweet little tractor that will move some serious material, I can assure you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
