Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Join Date
    Sep 2010
    Posts
    1,065
    Virginia
    5210 MFWD
    Default Re: John Deere 5103 injector solenoid fuse blown
    JHL, the temperature sensor is part # RE503242. I have attached pictures.
    I do not know what the cold weather switch is. Maybe this is what you are referencing, on the thermostat housing there is a temperature sensor that is connected to a two wire harness that goes to the injection pump; this is the "cold start advance" portion of the system so it starts easier when cold by advancing the timing.
    The temperature sensor is easy to replace. If you are quick changing it, you don't have to drain the coolant, just make sure it's not hot at the time. You will want a pan under the tractor to catch the coolant, so as not too have to clean it up.
    Hope this answers your question.
    Attached Thumbnails Attached Thumbnails John Deere 5103 injector solenoid fuse blown-temperaturesenor-jpg   John Deere 5103 injector solenoid fuse blown-re503242-jpg
  2. #12
    Gold Member AGGIE00's Avatar
    Join Date
    May 2010
    Posts
    473
    The problem is the thermostor, not thermostat. It is a 3 dollar part soldered in behind the fuse panel. It is a small 3/8" by 3/8" orange wafer with two wires extending out. Many replace the solenoid when it is not the problem.
    MY2012 John Deere 5083e-563 FEL, 2008 CAT 272C with 60" Bradco Mulching Head
  3. #13
    New Member
    Join Date
    Jun 2012
    Posts
    4
    onalaska wa
    Had the same problem I think. Blew the fuse to the solenoid. Replaced it and did it again.
    It runs fine without the solenoid temp hooked up.
  4. #14
    Join Date
    Sep 2010
    Posts
    1,065
    Virginia
    5210 MFWD
    The following was taken from the JD CTM125 manual on the 2.9L Engine. Even though the tractor starts-up, I still suggest you replace the sensor.
    When coolant temperature is below 122 F, the solenoid valve is activated and opens the cold advance circuit. This directs transfer pump pressure to the cold advance piston, forcing the advance piston to the fully advanced position.
  5. #15
    New Member
    Join Date
    Jun 2012
    Posts
    4
    onalaska wa
    Sounds like a plan. As soon as I get to town Ill see the JD folks. Thanks.
  6. #16
    Join Date
    Mar 2010
    Posts
    63
    Mine is doing the same thing. Never had any trouble before this. Any one got a part # for the thermostor? Maybe a picture of it?
  7. #17
    Join Date
    Sep 2010
    Posts
    1,065
    Virginia
    5210 MFWD
    You might want to look at thread #11 of this post for part # and picture,
  8. #18
    Join Date
    Mar 2010
    Posts
    63
    I was talking about the orange 3/8 piece that was mentioned earlier.
  9. #19
    Join Date
    Mar 2010
    Posts
    63
    Quote Originally Posted by AGGIE00 View Post
    Does anyone have a part # for this? Does it have to be soldered in?
  10. #20
    New Member
    Join Date
    Apr 2014
    Posts
    2
    Elgin, Texas
    Deere 5103
    I had this timing advance sensor shorting out my fuse. I measure it to be about 1ohm. Bought a new one. Guess what...it measures 1 ohm also. My guess is the short is occurring not between the two leads, but to the brass housing which connects to the chassis.
Similar Threads
  1. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 04:03 PM
  2. Should I do Skid Steer or should I stick to regular John Deere?
    By FRIZ in forum John Deere Owning/Operating
    Last Post: 06-02-2009, 07:52 PM
  3. John Deere 5103 or Kubota MX5000 4wd?
    By Stackwood in forum John Deere Buying/Pricing
    Last Post: 10-19-2006, 12:21 PM
  4. john deere 5103 vs kubota m4800
    By whitearrow in forum Buying/Pricing/Comparisons
    Last Post: 08-12-2005, 09:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
