Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Join Date
    Oct 2010
    Posts
    158
    1992/318 & 2010/2720 deere
    Default Question, I Match won't lift Bush hog
    I got an I match hitch to make life easy with my bush hog, only to find out that the center hook allows the floating link on the Taylor way bush hog to roll out of the hook when it takes the weight. Would anyone here recommend welding that link so it can't move? Seems like the only way I will be able to lift the thing.---------- Suggestions please!!--------- I was sold on this Taylor way bush hog by my dealer because he said the JD 5 foot hog was more expensive and the Taylor way was a better implement
    because of a slip clutch rather than a shear pin.
    Wooden
    Attached Thumbnails Attached Thumbnails Question, I Match won't lift Bush hog-3pt-hitch-001-jpg
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,773
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: Question, I Match won't lift Bush hog
    Looks like you will just have to re-make that top end to work with the iMatch. Believe me, it will be worth it.
    I replaced the steel straps from that top end to the rear of the hog with chains. Then I take that bolt out and just use one of the short steel straps to connect to the top arm pin of the iMatch (have a long enough pin there so it fits nicely. A rigid configuration could be welded for it, but have to get off to connect the PTO shaft so it isn't any extra pain to fasten to that top pin.
    Attached Images Attached Images
  3. #3
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I can see what you mean, nothing to hold the top link in the hook.
    What I would try is to take the bowed front pieces out of the rear joint and move them forward to the front joint. Make sure the bowed pieces can swivel and use nylok nuts to keep them from working loose. In essense you move the swivel point behind the fixed yoke.
    Make sure the top link is spaced correctly for the IMatch, that is 15" vertically higher than the lower hitch pins center to center.
  4. #4
    Join Date
    Oct 2010
    Posts
    158
    Quote Originally Posted by beenthere View Post
    I see you have a JD bush hog, so why then did you have to modify to fit the I match? And what would the ill effect be if I welded that link to the 15" required for the I match? Is it there as a floater for going over bumps? Seems to me when the hog is attatch straight to the 3 PT hitch, there is no need for a floating link? am I wrong?
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,773
    Upper Midwest USA
    My Deere 513 rotary cutter is older model and not iMatch compatible.
    The chains allow the deck to float (much more than the short floating link straps will allow).
    The long support steel straps will bend without the floater links, as the deck will not lift the 3 ph arms when the rear wants to lift up. The chains go slack, and is why the chains are much better than the steel straps. (for extreme emphasis, posted this pic)
    You can almost see one of the short floating straps attached to the top arm pin of the 3 ph. The top hook of the iMatch doesn't connect to anything on the 513 RC
    Attached Thumbnails Attached Thumbnails Question, I Match won't lift Bush hog-rc513bank-jpg
  6. #6
    Join Date
    Oct 2010
    Posts
    158
    I think what I am going to try is welding that link to the 15 inch height , but I'll change out the rigid straps to chains as in your case. It's the only way I can see to use the I match and still have the flexibility of a floating back. Thanks for the pic, it helped to clear things up in my mind.
    I am still open for other ideas from anyone that have them.!!
  7. #7
    Gold Member
    Join Date
    Jan 2011
    Posts
    263
    IN
    Kioti CK30, JD X475. HPX Gator, Woodmizer LT10
    I don't have an idea but I do know that when you buy a new rotary cutter, it has to be I-match compatible. The only brand that would be is the Frintier of course since it is Deere. No other brand cuuter will work on the I match.
    In the past when the 513's and LX 5's were sold, when you set that cutter up, you could set it up either way. It all has to do w/ the configuration of the floating top link on the cutter and how it setys in the "hook". It still has to float and slide.
    I have an I-match hitch but have a Land Pride cutter that is not compatible, during mowing season, I just take the I-match off and hook to the 3 pt. hitch.
    W/ an I-match, you have to be flexible since not all implements hook to it.
  8. #8
    Gold Member
    Join Date
    Jan 2011
    Posts
    263
    IN
    I don't have an idea but I do know that when you buy a new rotary cutter, it has to be I-match compatible. The only brand that would be is the Frontier of course since it is Deere. No other brand cutter will work on the I match.
    In the past when the 513's and LX 5's were sold, when you set that cutter up, you could set it up either way. It all has to do w/ the configuration of the floating top link on the cutter and how it sets in the "hook". It still has to float and slide.
    I have an I-match hitch but have a Land Pride cutter that is not compatible so during mowing season, I just take the I-Match off and hook to the 3 pt. hitch.
  9. #9
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,773
    Upper Midwest USA
    TT
    Most attachments can be made to work on the quick hitches, that include the iMatch. Takes some ingenuity and fabrication, but can be done if desired.
    The only attachment I have that I've not changed out is a used tiller. I'm on the lookout for a Deere tiller so am not investing any time or effort to make it iMatch compatible.
  10. #10
    Veteran Member countrybumpkin's Avatar
    Join Date
    Jun 2005
    Posts
    2,274
    Southeast Missouri
    Kubota L3410; Kioti NX5510C
    Really no need to weld anything, just remove the swinging top link and replace with appropriate spacer for the top hook,if the distance is correct from the bottom pins to were the top link bolt is, then replace ridged supports with chain like you had in mind.
    If your going to be a Bear, Be a Grizzly!
Similar Threads
  1. Rotary Cutter 60" or 72" Bush Hog for brush clearing with 40hp
    By IslandTractor in forum Attachments
    Last Post: 11-03-2011, 12:00 PM
  2. Quick lift capacity question
    By Piston in forum Owning/Operating
    Last Post: 01-08-2011, 09:52 AM
  3. Rotary Cutter Landpride bush hog question
    By gaswamp in forum Attachments
    Last Post: 06-12-2009, 07:54 PM
  4. L4310 and Bush Hog M246 FEL
    By Enspect in forum Kubota Owning/Operating
    Last Post: 08-07-2007, 01:08 AM
  5. Rotary Cutter Ford bush hog 10ft - question about blades
    By Pooh_Bear in forum Attachments
    Last Post: 07-17-2007, 05:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
