Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Didn't intend to have a Deere fleet - it just happened
    Default Spun rod end bearings
    I have a deere 310C backhoe. There are several sleeve bearings (steering, bucket and swing) that have spun, blocking the grease fitting port. The bearing sleeve material is very hard. A High speed drill bit won't scratch it. I'd like to drill a new grease hole through the bearing to the internal grease channel.
    Anybody have a suggestion or experience on how to accomplish this??
    Thanks for your thoughts...
  2. #2
    Super Member
    Join Date
    Feb 2006
    Posts
    6,768
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Default Re: Spun rod end bearings
    A carbide bit would do it. But whats to keep it from spinning again?
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, Hesston Haybine, JD Rake
    Bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  3. #3
    Veteran Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,402
    Hooksett, NH
    Kubota B2320
    hosspuller,
    those bushings are hardened and precision ground to size after.....
    the best way to drill them out is to remove them and heat the area that you'll drill with an oxy/acet torch red hot, then it cool natually......this will anneal the hardened steel allowing you to drill them with conventional drill bits....
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  4. #4
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Quote Originally Posted by SPYDERLK View Post
    larry
    Thanks for the replies...
    I'm thinking the bearings got spun due to lack of lub. The machine was city owned. Their operators weren't the most dilligent with daily maintenance. Though, the shop did regular service on it.
    The bearings seem to be very tightly pressed in. I'm trying to avoid a total tear-down of the affected bearings. Taking the backhoe apart is a major job with pieces weighing thousands of #. If I were to press out the sleeves, I could reinstall them with the hole aligned instead of drilling them.
    Any advice on the type of carbide bit? I've found a spade bit designed for glass and a solid flute type. I'll have to use a hand drill through the grease fitting hole. If I break the drill bit in the bearing... I'll really be hosed. I'm leaning toward the spade bit for this reason...
  5. #5
    Join Date
    Jun 2002
    Posts
    527
    Rozet, Wyoming
    Most bushings like that will have a groove around the circumference of the bushings so the hole in the bushing does not have to line up with the hole in the rod ends. I would look at a new bushing from JD and see if that is the case or not. You might just have hardened grease, rust, dirt, etc. that you need to get freed up. I don't think you will have much luck drilling with a carbide bit in a hand drill. Solid carbide isn't very forgiving. You'll likely break the bit, and they are expensive. If it comes down to trying to drill, I'd just get some cheap masonry bits. You want the kind for a conventional drill, not the chisel point type that a hammer drill uses. If you need to sharpen them, you'll need a silicon carbide or diamond wheel.
    Kim
  6. #6
    Veteran Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    2,049
    South West MI
    John Deere 2030, John Deere 6415
    Might be easier to have some greaseable pins made.
  7. #7
    LD1
    LD1 is offline
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,484
    Central Ohio
    Kubota l3400
    Quote Originally Posted by KWentling View Post
    Kim
    That would be my guess too. If the bushing (or housing itself) isnt grooved it is a very poor design.
    Quote Originally Posted by Zebrafive View Post
    Typically the pins are hardned as well. NOT just mild steel. So that would also be $$$ to have them made. And they usually dont make the pins on a backhoe greasable due to strength. They want a SOLID pin, not one that has had holes drilled for grease.
    HOSSPULLER: exactally what pins/bushing are you talking about and maybe we can look up a parts diagram Most BH's have several different sizes and styles of bushings in the different locations.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  8. #8
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Thanks again for your interest...
    Here's an example: It's the steering cylinder rod end. Part #16
    The most troubling bearing is the lower pivot of the swing frame. part #7
    Attached Thumbnails Attached Thumbnails Spun rod end bearings-tp15104________un01jan94-1-.gif   Spun rod end bearings-tp17716________un01jan94-1-.gif
  9. #9
    LD1
    LD1 is offline
    Join Date
    Apr 2008
    Posts
    7,484
    Central Ohio
    Kubota l3400
    It appears in the diagram that the lower swing arm bushing IS grooved. so grease should get to where it needs to be regardless.
    The PS cylinder busing does appear to need to be lined up thougt.
    Have you tried drilling that one?? Because most of the time a bushing is used iin a cylinder rod, it is a bronze bushing, which should be no problem to drill.
    Ford 5500 Backhoe
    JD 261 3PH mower
    Dolmar 7900
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  10. #10
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Quote Originally Posted by LD1 View Post
    The PS cylinder is the bushing I tried to drill.I was able to remove the pin and clean eveything up. I greased the pin before reassembling but it sure makes it a chore to keep it lubed.
    The swing arm is definitely clogged up with dried grease. I tried heating it but maybe I was too timid about the amount of heat. I'm considering removing the lower pin to see if that might help clear the crud.
Similar Threads
  1. Rod vs Rail pallet forks - pros and cons.
    By Dan69GTX in forum Build-It Yourself
    Last Post: 04-25-2011, 12:08 PM
  2. Rotating cylinder rod?
    By jomifo in forum Hydraulics
    Last Post: 09-29-2009, 12:00 PM
  3. Leaking (internally) KL130 loader cylinders
    By Greenecho in forum Kioti Owning/Operating
    Last Post: 05-27-2009, 01:13 PM
  4. tie rod dust seal
    By kbota in forum Parts/Repairs
    Last Post: 09-04-2007, 01:53 PM
  5. Grapple Grapple top forks the pressure won't release
    By millpond in forum Attachments
    Last Post: 08-17-2007, 05:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
