This is the easiest way I have found to grease the dreaded 2320 driveshaft that connects the engine to the transmission.
After removing 8 or 10 screws and loosening the throttle bolt, I am able to seperate the top and botton dash components enough that I can move the lower panel out of the way and expose/remove the service hatch on the right hand side. Using a wrench to turn the crank, I was able to get the grease gun onto that nipple. The rear U-Joint is accessible from underneath the tractor.
Anyone found an easier way?
