Results 1 to 2 of 2
07-05-2011, 01:37 PM #1New Member
- Join Date
- Jul 2011
- Posts
- 1
- Tractor
- John Deere 6220
6220 STOP Low transmission pressure
Hey, When I unplug the pressure sensor just above the filter on the rear of the transmission the light goes out, and I can view which gear I am in and other info & messages. When I plug it back in the STOP light keeps flashing and I can only read the fixed message about changing filters, and checking fluid level because the transmission pressure is low. Everything seems to be working fine.....1500 hours, new filters, new oil, and new lines from the big filter by the rear tire. What else could be wrong?
07-05-2011, 10:03 PM #2Platinum Member
- Join Date
- Dec 2001
- Posts
- 751
- Location
- Maryland
Re: 6220 STOP Low transmission pressure
Sounds like the filter restriction sensor is bad. Actually sensor on filter on front of transmission is on same circuit, so it could be either one. If unhooking rear one makes warning go away, I would replace that one first. What kind of oil are you using in trans? I had to change oil in one tractor to get this message from coming back. It drove me crazy.
Similar Threads
hydr motor pressure limit question how to restrict power output
By burntside bob in forum HydraulicsReplies: 13Last Post: 06-27-2010, 06:03 AM -
Transmission Oil Leak ... Can I Stop It?
By vern6973 in forum Oil, Fuel & LubricantsReplies: 8Last Post: 07-25-2009, 11:29 AM -
How to recover from low oil in Hydro transmission ?
By westcliffe01 in forum Parts/RepairsReplies: 7Last Post: 07-09-2009, 11:09 PM -
Backhoe BX24 backhoe left and right motion low pressure
By henry1088 in forum Kubota Owning/OperatingReplies: 6Last Post: 09-15-2008, 08:30 PM -
Water Pressure
By MarkV in forum Rural LivingReplies: 32Last Post: 02-26-2001, 08:25 PM
