I have a JD level indicator on my 430 loader. As described earlier, a rod attached to the pivot point for the bucket, runs up through a tube on the loader arm. The rod slides up and down through the tube as you tilt the bucket. The rod is easily visible from the seat. The directions with the indicator tell you to level the bucket on the ground and mark the rod at the point it extends out of the tube with paint or tape, or cut off the rod at that point making it flush with the top of the tube. I chose to cut mine off and paint the end of the rod white. Now when the white tip of the rod is flush with the tube I know that the bucket will be level when it is touching the ground on a level surface. I also have the JD forks for my loader and when they're level the tip of the rod will be approx. 1/2" below the top of the tube, also very easy to see. My indicator came with the loader but the dealer did tell me, as I remember, that it's about $35 if you buy it separately. It's not a perfect device since it only indicates level bucket to level ground but it will get you within a few degrees of where you want to be at any time on any ground. You could probably build one yourself for $10, and if you want the dimensions for it I'd be happy to go out and measure mine and send you a detailed drawing.
Branch
