Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Jun 2011
    Posts
    11
    John Deere 2520
    Default 2520 mounting switch in dash
    I need to mount a rocker switch in the dash of my 2520, it will be used to control an actuator that I mounting to my snowblower for chute deflector control. I would like to install it in the dash next to the throttle to the right of the gauges or just below it. Has anyone installed any switch or something other in their dash? Or has anyone had thier dash apart or the fuel tank out to get under the dash?
  2. #2
    Gold Member PCABE5's Avatar
    Join Date
    Oct 2007
    Posts
    281
    NW Wisconsin
    JD 2520
    Default
    I installed a temp gauge. You need to pull the top part of the dash as it is two halves:
    1. Remove steering wheel
    2. Remove throttle lever
    3. Remove 4 bolts (two under the steering wheel rubber and one towards starter and one towards the fuel separator you need the hood open to get these). You will see them when you open the hood.
    4. Remove top of the dash (be careful of the wires and tach cable).
    5. Drill any holes from the backside as the cluster is bigger than it looks.
    Send us some photos of your project.
    2011 JD 2520 | 72" MMM | 200CX FEL 73" bucket | JD 54" Fr Blade | Michigan Suspension Seat | SpeeCo Q-Hitch | JD Ballast-Box | 5ft King Kutter Brush Cutter |
  3. #3
    Join Date
    Mar 2005
    Posts
    2,432
    Bedford, VA
    John Deere 2320
    Default Re: 2520 mounting switch in dash
    here is a link to the entire procedure from another forum..
    While you got everything apart, it would be a great time for the temp gauge..
    http://www.mytractorforum.com/showthread.php?t=145772
    brian
    Bedford, VA
    2320 w/ 62D MMM, 200CX FEL, Pats EZ Change, LX4 Cutter
    Co-owner (with my father) of John Deere 790, 30 HP, 4x4, 513 cutter, 70 FEL
    2012 Nissan Xterra Pro-4x
  4. #4
    New Member
    Join Date
    Jun 2011
    Posts
    11
    John Deere 2520
    Thanks for the feedback and the link to the other site was just what I needed. A good visual always helps.
  5. #5
    Join Date
    Mar 2005
    Posts
    2,432
    Bedford, VA
    John Deere 2320
    Quote Originally Posted by deere 2520 View Post
    I had saved the link because a thermostat upgrade for my 2320 is in the near future and those pics really did a great job of showing anyone how..
    brian
    Bedford, VA
  6. #6
    Join Date
    Oct 2007
    Posts
    281
    NW Wisconsin
    JD 2520
    Default
    Quote Originally Posted by thatguy
    brian
    That site is what I used when I installed my gauge on the old 2320 and my new 2520. Even used the same gauge on both.
  7. #7
    Silver Member lost in wisconsin's Avatar
    Join Date
    May 2010
    Posts
    145
    Wisconsin
    John Deere 2520 (2011)
    deere 2520,
    It appears as if you are tackling the project I did last winter on my 2320. As advised by the other posters...the process is pretty simple to remove the dash. I used a hot knife to cut the hole in my dash. Below are some pics of my dash and finished product.
    lost
    Attached Thumbnails Attached Thumbnails 2520 mounting switch in dash-img_0827.jpg   2520 mounting switch in dash-img_0828.jpg   2520 mounting switch in dash-img_0919.jpg   2520 mounting switch in dash-img_0865.jpg   2520 mounting switch in dash-img_0819.jpg
    2011 JD 2520, 200CX FEL w/ 53" bucket, iMatch Quick Hitch, 48" JD Box Scraper, 54" JD FM Snowblower, Frontier PHD200, BB & Heavy Hitch
    My basic principle is that you don’t make decisions because they are easy; you don’t make them because they’re popular; you make them because they’re right. Theodore Hesburgh
  8. #8
    New Member
    Join Date
    Jun 2011
    Posts
    11
    John Deere 2520
    Please provide details on actuator, switch and wire. What is the make and model is the actuator? Where did you purchase it? Where did find a DPDT monentary rocker switch with up down on it? What gauge wire did you use? Where did you tap in for power? Is the actuator powerful enough to hold and move the deflector in heavy deep snow?
  9. #9
    Join Date
    May 2010
    Posts
    145
    Wisconsin
    deere 2520,
    I have all that info and can provide later tonight or tomorrow. My CFO is standing behind me now wondering why I am on this forum rather than getting myself ready to take her out for a well deserved dinner.
    lost
    oh...i found some time and here is a quickie of my BOM and pic of materials
    a. Liner Actuator (15 lbs, 12v, 4 Stroke)
    Source Firgelli Automations (Linear Actuators, Linear Motors, Micro motors, Electric Motors)
    PN - FA-MS-15-12-4
    Cost - $75.00
    b. Momentary Contact Rocker Switch
    PN - MAN-RS2
    Cost - $18.00
    c. 16 Gage Wire (2 colors for a someone like me to keep straight)
    d. 16 Gage Heat Shrink Butt Connectors and Quick Disconnectors
    e. In Line 12v Fuse Holder
    f. 2 Wire Flat 12v Connector
    g. Hardware
    2 Stainless Steel Hex Head Bolts ï½¼ x 1 ï½½
    4 Stainless Steel Nylock ï½¼ Nuts
    h. Flex Tubing and Kwik Clips
    Attached Thumbnails Attached Thumbnails 2520 mounting switch in dash-img_0817.jpg
  10. #10
    New Member
    Join Date
    Jun 2011
    Posts
    11
    John Deere 2520
    Very helpful, thank you!
Similar Threads
  1. TC40 Rabbit / Turtle switch not working, switch and relays replaced.
    By IsuzuDon in forum New Holland Owning/Operating
    Last Post: 03-20-2011, 07:24 PM
  2. Ready to pulled the trigger on the 2520 but
    By hodoms in forum John Deere Buying/Pricing
    Last Post: 01-07-2008, 08:49 PM
  3. 2520 first impressions vs 2210
    By bheston in forum John Deere Buying/Pricing
    Last Post: 07-28-2007, 06:58 AM
  4. 2520 REVEALED!!
    By Dutch445 in forum John Deere Buying/Pricing
    Last Post: 10-10-2005, 10:59 AM
  5. P/U Dumpbed conversion
    By scruffy in forum Rural Living
    Last Post: 08-08-2001, 06:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
