Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
  1. #11
    Silver Member lost in wisconsin's Avatar
    Join Date
    May 2010
    Posts
    158
    Wisconsin
    John Deere 2520 (2011)
    Default Re: Electric Actuator for Spout Control (JD 2320)
    And finally...the finished mod. I estimate this took about 6-8 hours for me. It was well worth my time and effort.
    lost
    Attached Thumbnails Attached Thumbnails Electric Actuator for Spout Control (JD 2320)-img_0919-jpg   Electric Actuator for Spout Control (JD 2320)-img_0865-jpg
    2011 JD 2520, 200CX FEL w/ 53" bucket, iMatch Quick Hitch, 48" JD Box Scraper, 54" JD FM Snowblower, Frontier PHD200, BB & Heavy Hitch
    My basic principle is that you don’t make decisions because they are easy; you don’t make them because they’re popular; you make them because they’re right. Theodore Hesburgh
  2. #12
    Bronze Member boughtaJD's Avatar
    Join Date
    Mar 2009
    Posts
    60
    mid Michigan
    JD 2320
    Nice write-up. Now we need to see video in action once the snow flies
    JD 2320, 200CX FEL, Frontier box blade, 54D MMM, LX5 rotary cutter, pallet forks, FEL plow, grapple
  3. #13
    Gold Member jjmarotz's Avatar
    Join Date
    Oct 2007
    Posts
    373
    Ashton, Idaho
    JD 3720 cab
    Nice setup.
    Couple questions for you. How long have you used this? And how is it holding up so far? Reason I ask is I did the electric actuator mod last yr to my 59" and after a couple weeks the 1/4" bolts sheared off the chute. Too much vibration with the snow pounding on the chute. Can't use larger bolts due to the "ball and socket" type ends on my actuator. Thanks.
  4. #14
    Join Date
    May 2010
    Posts
    158
    Wisconsin
    jj...
    I have used it since January of this year and we had about 5 ft since I installed it. I think I understand what you mean by ball and socket at the ends of the actuator. I did use 1/4" also and actually had to drill out the one end of the actuator to accept the 1/4, I think it was drilled for 3/16.
    Anyway, I have had no issues. The only recommendation I might offer, is either getting a higher grade bolt (again not sure what you were using) since more store bought bolts are grade 2 or if you go back to post #4 of my thread, you will see I actually used 2 nylock nuts and lock washer to secure the actuator to the spout. I did it for spacing and clearance reasons but I have to imagine the load on bolt is less than fastening it the conventional way.
    Let me know if there is any further information I could provide.
    lost
  5. #15
    Bronze Member North585's Avatar
    Join Date
    Jul 2006
    Posts
    63
    Northern Alberta
    X585/2720
    Thanks for the great post lost. The instructions are excellent. It will help me with my project this fall for my 47".
    Much appreciated.
    3320 w/ Imatch, 300CX, 375 BH, 5' box blade, b box
    X748 w/ 62" and 54" deck, 47" blower, 54" blade
  6. #16
    New Member
    Join Date
    Oct 2010
    Posts
    6
    Northern WI
    john deere 3720
    Lost in WI-- We tried the electric actuator on a couple 59 inch blowers we have had over the years and found that they freeze up after using in cold temps. We now run a couple hoses to the rear 3rd hydraulics and use an old boat ram from the lower unit on I/O's. Real cheap to find and has enough power to not freeze up. Have to be careful not to extend beyond reach of ram or you will shear bolts on chute.
  7. #17
    Join Date
    May 2010
    Posts
    158
    Wisconsin
    beaner...
    May I ask if your snowblowers were/are kept inside or outside. Just wondering if that might have anything to do with the life of an actuator.
    thanks,
    lost
  8. #18
    Member damiang's Avatar
    Join Date
    Feb 2011
    Posts
    41
    Bangor PA
    2011 John Deere 2520
    Quote Originally Posted by lost in wisconsin View Post
    lost
    GREAT job and excellent explaination
  9. #19
    Gold Member psdx's Avatar
    Join Date
    Nov 2006
    Posts
    457
    London, OH
    Kubota B3030
    Default
    Quote Originally Posted by North585
    Much appreciated.
    Did you add this to your 47" JD snowblower yet? I'm about to start.
    Kubota B3030, LA403 FEL, Woods RB72 Back Blade, LandPride GS1560 Grading Scraper, Frontier CA2060E Aerator, Kubota ZD331-72 mower, John Deere x575 & 47" snowblower
  10. #20
    Join Date
    Nov 2006
    Posts
    457
    London, OH
    Kubota B3030
    Default
    For anyone with the JD 47" snowblower that's interested, I found an actuator that gives you 99% of the spout travel available and uses the factory mounting holes for the manual spout control kit. The actuator I used has built-in limits that give 4" of travel which works out perfectly for using the factory holes.
    Here's the materials I got from http://www.dcactuators.com/
    Product ID: 302.130_6104T
    Description: 4" Linear Actuator (Speed 1/2" per Sec.)"IP65 Rated" - Price: $114.00
    Product ID: 302.660_8639T
    Description: Mounting Bracket For (T) & (TP) Series Actuators - Price: $7.00
    Product ID: 306.580_242
    Description: Momentary Off DPDT Rocker Switch - Price: $5.25
    I used the clevis bracket at the bottom and a bolt with a spacer and nylon washers at the top. The clevis bracket gives you just a little bit of offset. This gave me 100% of the up travel and about 99% of the down travel. The spout is slightly below horizontal when it stops so this works for me. I started with clevis brackets on both ends but this gave me too much travel or not quite enough depending on which way the bracket was oriented. Also - the clevis bracket needed to have a little material cut off the end to allow the actuator to work with the bracket flat like this - no big deal. I put nylon washers behind the moving parts to let things move freely and not scratch the paint all up. And I used a two-wire flat disconnect at the front of the tractor for removal of the snowblower in the spring.
    ....thought this list of materials might same someone some time.
    BTW, the JD kit is $114 for the manual cable spout control, but each specific tractor application needs 2-3 brackets and some miscellaneous hardware. In my case, the other stuff added up to another $100 so this is much less expensive.
    Attached Thumbnails Attached Thumbnails Electric Actuator for Spout Control (JD 2320)-image-4160032225-png   Electric Actuator for Spout Control (JD 2320)-image-3126615046-png   Electric Actuator for Spout Control (JD 2320)-image-3634920511-png
Similar Threads
  1. Manual to electric control of control valve
    By Grammargarcia in forum Hydraulics
    Last Post: 04-07-2010, 12:30 AM
  2. Buying Advice 2007 Kubota BX 24 or Brand new JD 2320
    By scrivy69 in forum Buying/Pricing/Comparisons
    Last Post: 04-06-2010, 01:20 PM
  3. Snow Attachments Alternative snow plows for JD 2320?
    By Phil D in forum Snow Removal
    Last Post: 03-29-2010, 09:55 PM
  4. JD 2320 measurements
    By 2305JD in forum John Deere Owning/Operating
    Last Post: 03-19-2008, 06:14 PM
  5. JD 2320 vs. JD 790
    By elalexander in forum John Deere Buying/Pricing
    Last Post: 08-26-2007, 08:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
