Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    New Member
    Join Date
    May 2011
    Posts
    18
    Ludlow, MA, USA
    2011 John Deere 2520
    Default Finally got new Deere 2520 this weekend
    After waiting 2 months, I finally got my new 2520 this weekend. It has the 200cx loader w/61" bucket and 46 backhoe. Put about 3 hrs on it so far, mostly "feeling" it out and learning to use the backhoe. It is my first tractor, so I really have no reference to compare it to. Plan on getting a box blade to help spread some dirt. Love that diesel drumming!
  2. #2
    Veteran Member JDGREEN4ME's Avatar
    Join Date
    Sep 2002
    Posts
    2,245
    Southeast PA
    John Deere 2520, John Deere X534, John Deere LT150
    Default Re: Finally got new Deere 2520 this weekend
    Congratulations!
    "We can judge the heart of a man by his treatment of animals"
    Immanuel Kant
  3. #3
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,135
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Congratulations on the new tractor.
    Get some seat time and enjoy it. A word of advice with the backhoe, watch that you donlt hit the stabilizers with the bucket.
  4. #4
    Gold Member PossumHound's Avatar
    Join Date
    Apr 2010
    Posts
    445
    North Carolina
    Congrats, nice rig. Send pics soon
    PH
  5. #5
    New Member
    Join Date
    May 2011
    Posts
    18
    Ludlow, MA, USA
    Thanks, and duly noted on the backhoe tip. Any tips that would help a newbie are welcome. I have about an acre of woods behind the back yard on a very rocky piece of property that I want to tame, so the kids can use it. I think I need some forks to help pick up + move some rocks around. I also want to spread some dirt around where the lawn has settled since construction 5 yrs ago. How much abuse can one of these rigs take, as far as bouncing around on less-than-even terrain? Has anybody broken the cast steel "backbone" in the middle (under the floor) or the hub reduction boxes @ the rear wheels? Those just (visually) seem like weak links if things got rough, but what the heck do I know? Don't get me wrong; I'm gentle on it & realize it's not a bulldozer or serious construction equip, + I'm scared-stiff of tipping it over. Wish I could afford some implements & attachments, but it took all I could scrape up to buy the machine. Gotta put some water back in the well!
  6. #6
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    Strange,
    Congratulations! I'm sure you'll love the machine.
    Here is a tip: If/when you need to detach the loader bucket (to attach your forks, etc.) don't get lazy and try to leave your lynch pins hanging by their cables. They will get caught under the bottom of the bucket mounts and break the cables. It's better to get in the habit of reattaching them to the extra mouning points on the bucket mount when they are not in use.
    Not a big deal, but a way to preserve the cables.
    Also, be gentle with your range shift lever. There have been threads on here about the pins that hold the levers breaking off inside the case and it's a bear to fix.
    Oh, here's one more thing I learned. If you need to attach a drive shaft to either the mid or rear PTO, shift the PTO control lever to the opposite PTO from the one you are using. This allows you to easily rotate the PTO stub to line up with the splines on the drive shaft. It is a REAL pain in the neck to do it otherwise.
    I wish you the best of luck with your new machine!
    Runner
  7. #7
    Gold Member pdp11's Avatar
    Join Date
    Nov 2010
    Posts
    266
    Pittsboro, NC
    John Deere 2520 CT
    Default
    In general, the 2520 seems to be a pretty stout little tractor. As with anything, it's possible to break it if you push it well beyond what it is capable of. If you stay within the range of attachments that were designed for use with a tractor of this size, you shouldn't get into trouble. Proper ballasting will help a great deal with the FEL.
    If you haven't already had it done by the dealer, make sure the rear tires are set to the wide stance (valve stems on the inside). This will make the tractor more stable, especially when using the FEL.
    John Deere 2520 - 200CX, 62D, RB2060
    John Deere 316 - 38" Deck, 3pt Hitch
  8. #8
    Platinum Member glc24's Avatar
    Join Date
    Dec 2009
    Posts
    896
    Southwestern, Pa.
    Congrats on your new machine!
    I'm thinking you will thoroughly enjoy your 2520.
    Yes!
    Not sure which forum,but someone broke a reduction hub on his 2520.
    BUT!! As you stated,if common sense is constantly in use,these kinds of things won't happen.
    Greg
    2009 2520
    FEL/61" HD bucket/replaceable cutting edge
    62D2 MMM
    IMatch Quick Hitch
    Homemade 3PT Receiver
    Homemade Ballast Box
    Woods GB65 Box Blade
    A "REAL" snow blade --- JD 380A
    90% Restored 1987 JD 316
    MY BALLAST BOX:
    http://www.tractorbynet.com/forums/b...box-build.html
    MY SE SEAT 2520 MOD:
    http://www.tractorbynet.com/forums/j...my-2520-a.html
  9. #9
    New Member
    Join Date
    May 2011
    Posts
    18
    Ludlow, MA, USA
    How much wider does flipping the wheels make it? Thanks for all the tips, btw! Also, has anybody used the loader bucket to push snow? I realize it's not ideal, but does it work at all, say, in "float", or am I just going to make a fool of myself trying? I can't really afford a plow attachment for a while. Don't want to embarrass team green. How much traction do the R4's get on pavement pushing snow? The drive is a long, gentle slope.
  10. #10
    Gold Member PCABE5's Avatar
    Join Date
    Oct 2007
    Posts
    291
    NW Wisconsin
    JD 2520
    Default
    Quote Originally Posted by Strangerover
    Flipping is about 2 inches. The 200cx manual recommends the wide position.
    As for using the loader for snow removal, it does a good job but is slower than other methods. If you think you'll embarrass team green then I've doing it for years as a loader is all I've used. You'll have to see how the traction goes, I do not run chains but others do. I just push the big stuff down hill. My drive is gravel so I leave a snow layer down. Chains may mark your asphalt and that is something to think about.
    2012 JD 2720 | 72" MMM | Curtis Hard Cab | 200CX FEL 73" bucket | JD 72" Rr Blade | Michigan Suspension Seat | SpeeCo Q-Hitch | JD Ballast-Box | 5ft King Kutter Brush Cutter |
Similar Threads
  1. John Deere 2520 power
    By GMCSierra in forum John Deere Owning/Operating
    Last Post: 05-25-2011, 11:37 PM
  2. uses for the john deere 2520
    By HammA5690 in forum John Deere Buying/Pricing
    Last Post: 03-01-2011, 12:27 PM
  3. Purchasing Help on used John Deere 2520
    By Ed G in forum Buying/Pricing/Comparisons
    Last Post: 11-04-2009, 04:08 PM
  4. deere 2520 and kubota b3030 thoughts
    By strokerduster in forum John Deere Owning/Operating
    Last Post: 06-20-2007, 12:53 AM
  5. Home Depot
    By BrokerBob in forum John Deere Buying/Pricing
    Last Post: 07-12-2002, 09:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
