Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    6
    Default 1961 3010
    need to move rear wheels in more how is this done correctly
  2. #2
    Join Date
    Dec 2001
    Posts
    752
    Maryland
    Default Re: 1961 3010
    Assuming you have rack and pinion axles. This can be very difficult if the wheels have not been moved for many years, but this is the procedure. Jack up the tractor and turn the axle until the "teeth" in axle are turned up. loosen the three large bolts(1 5/16" socket) about 6 or 8 turns, About an inch. Tighten the 2 smaller bolts(1 1/16" socket) to push in the wedge to loosen. After the wedge is loose, then turn the pinion shaft(the other 1 1/16 bolt) to roll the wheel in or out. The problem is that all the bolts and wedges tend to get very tight after not getting moved for 40 or 50 years.
  3. #3
    Join Date
    Jan 2007
    Posts
    1,944
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    IIRC JD only offered rack & pinion rear wheels on a 3010. To add to what JD110 stated JD factory service managers recommended hitting end of axle with a sledge hammer to help loosen the wedges. On another tractor site I've seen a poster state that he fabricated a heavy piece of pipe cutout on one end to just touch the one wedge,slid on axle and hit with sledge hammer.
  4. #4
    New Member
    Join Date
    Aug 2011
    Posts
    6
    info from both u guys came in very handy had to use the sledge on both side lots of rust but in the end they moved in. Have been mowing like crazy for the last 4 or 5 day i love this tractor. Used a little massy 35 last year done the job but a lot slower.
  5. #5
    Join Date
    Jan 2007
    Posts
    1,944
    Coyote Flats,Tx
    Keep an eye on the 4 bolts that secure the pto stub shaft on to tractor. If they get loose it can cause you major repairs.
Similar Threads
  1. John Deere 3010 parts
    By lowellches in forum John Deere Buying/Pricing
    Last Post: 09-25-2004, 08:55 PM
  2. Ready to purchase but...??? 3010, 3130...
    By norcal in forum Kubota Buying/Pricing
    Last Post: 06-19-2003, 02:56 AM
  3. Trade B2910 for 3010?
    By kch in forum Kubota Buying/Pricing
    Last Post: 02-07-2003, 01:53 AM
  4. Is a 3010 HST overkill?
    By crown in forum Kubota Buying/Pricing
    Last Post: 08-26-2002, 08:57 AM
  5. L 3010 vs L 3410
    By Steve_Carver in forum Kubota Buying/Pricing
    Last Post: 06-30-2001, 09:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
