Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Jul 2002
    Posts
    64
    Ortonville, MI
    Deere 3320 w/eHydro
    Default 54" Front Blade - issues?
    I have a 1026R unit that measures approx. 45" wide - If I was to use the Deere 54" blade angled at 30 degrees, it would clear about a 46.5" path. I know a wider blade would be better and I've searched for 60/66" blades to no avail.
    After reading most of the discussion topics related to the Deere 54" front blade, the only issue I can find is the blade isn't wide enough. I can't find anyone complaining about the trip springs, hitching or unhitching, weight, or anything else.
    Have I missed any another problems with the Deere unit? I have a couple of resources that could weld on extensions for me after I get the package from the dealer. I could always hand a shovel to the wife so she could walk next to the tractor to help with the overflow...
    I'm running R3 turfs and don't expect any traction issues - same set-up I used with a 4115 a few years ago.
    Thanks,
    Steve
  2. #2
    Join Date
    May 2011
    Posts
    81
    1986 john deere 318
    Default Re: 54" Front Blade - issues?
    Steve the 54in blade was designed for the normal run of the mill gardern tractors like the old 300 series and some of the 200 series gt's as well. Your tractor is a touch bigger then these models so it really not designed for your size of machine. JD does make a larger blade but I cant remember exactly what size they are sorry. I have seen a few 54in. blades where people have put on "wings" to help with the width of them though. Perhaps you could take it to a fab shop and they would make you a couple to get it a little wider to help with your tractor.... Gary
  3. #3
    Join Date
    Jun 2006
    Posts
    130
    Rockford MI
    search arthurrandalcorp.com or search john deere plow on you tube they make a 60" stainless steel plow for the jd quick hitch.
  4. #4
    Gold Member XSKIER's Avatar
    Join Date
    Apr 2011
    Posts
    451
    Fenton, MI
    '11 Deere 1026R
    Default
    As far as I can tell, the 54" should eject the material far enough. The pivot point is a good ways back from the cutting edge, effectively throwing the blade over more. I haven't used mine yet, but I think it should work nicely.
  5. #5
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    This is my BX1500 with a 60" front blade with Hyd lift and angle.
    A 54'' blade is to narrow for a S-Compact tractor.
    JD misses the mark by not offering a 60'' mower .
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  6. #6
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,925
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by Steve_in_SEMich View Post
    Thanks,
    Steve
    That is the only complaint I have ever heard-they are not wide enough. JD does NOT make a wider one that will fit without fabrication. If you can get wings made for it then I say go for it.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  7. #7
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    I have a 72" Frontier blade on my 4520. Works great. I am a fan of Frontier implements, well built and fully supported by JD
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  8. #8
    Silver Member DP Property's Avatar
    Join Date
    Oct 2009
    Posts
    208
    BelleRiver, Ontario
    Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
    Quote Originally Posted by gbomalley View Post
    Hey Gary how do you like the 72 " blade on this machine? is it a loader blade and can you move a lot of snow with it in a relatively short period of time?
    I have ordered a 72" loader snow blade for the 300 cx loader from Horst welding. I have one of there 60" loader blades the 1000 series for my kubota 7510 la302 loader and it is excellent for my small tight little properties. I am hoping the 3720 will be ok to move some snow at one large church parking lot and community hall I have. They allow me to leave a machine there and this is nice as it gives my tractor full access to my downtown area in a minutes time. perfect when I want to get out of the truck for a while and go and do detail clean ups with the tractor. Here is the loader blade I am waiting for - HLA Snow
    2001 JD GT235 48 " deck
    2005 JD 757 60 " deck
    2006 F-350 6.0 crew cab
    2007 Kubota 7510B LA 302 loader
    2007 Miska 6 ton industrial dump
    2010 JD Gator 850 D
    2011 JD 3720 Cab 300 cx loader
  9. #9
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,297
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Quote Originally Posted by DP Property View Post
    Nice plow, DP!!
    What did that cost you, if I may ask?
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  10. #10
    Member
    Join Date
    Aug 2011
    Posts
    39
    Kubota BX24, Kubota L260
    Quote Originally Posted by XSKIER View Post
    ...thereby leaving more un-plowed area on the other side.
Similar Threads
  1. Front blade for dirt work?
    By Verticaltrx in forum Attachments
    Last Post: 09-26-2010, 12:13 PM
  2. tires
    By Waterrat in forum Parts/Repairs
    Last Post: 03-13-2009, 07:23 PM
  3. Grading Front Blade Experiences
    By cerescobra in forum Kubota Owning/Operating
    Last Post: 07-19-2008, 10:22 PM
  4. Grading Box Blade Grader Blade debate
    By SI2305 in forum John Deere Owning/Operating
    Last Post: 12-15-2006, 10:08 AM
  5. Front blade on 4300
    By Bob_Trevithick in forum Attachments
    Last Post: 12-10-2001, 09:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
