Hello, I need help with my JD 855. I cannot keep fuel flowing, as the level slowly drops in the fuel filter bowl until it starves out. It is a later model so it has the mechanical fuel pump which seems to be working fine. I can get the bowl to quickly fill if I bleed the air out of the bowl by loosening the middle screw on top of the fuel filter, but when I close it back up, the fuel level starts to drop again. It does not always drop at a constant rate, sometimes faster then other times. I have blown out all the lines, checked for any leaks and can't see any. The only thing that will keep the bowl full is holding my thumb over and plugging the return line to the tank. This builds pressure in the return line, but seems to keep the bowl full. Also, if I go to manually pump fuel into the bowl with the little lever on the side of the fuel pump, it will rise the level slowly, but then quickly drop again.
Any help would be sure be appreciated, as I have been scratching my head a while on this one!
