2305 and 2320 front snowblower quickhitch the same?
   / 2305 and 2320 front snowblower quickhitch the same? #1
purpony
CT
JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
wondering if the quickhitch for a 2305 and 2320 are interchangeable? Looking at a used snowblower and mount from a 2305 and wondering if it will bolt directly onto my 2320?
thanks
   / 2305 and 2320 front snowblower quickhitch the same? #2
Yes. You need the bracket that bolts to the tractor as well. The bracket is a combo for the q-hitch and mower deck.
i know they make a pretty beefy front bracket that bolts to the frame because i just recently put a mid mount mower on my 2320 and the dealer sent me both the 2 piece mower front mount and then a beefy one piece mount that i returned.
Here is the one i returned-
saleenlimited
I figured it was just for a snowblower....
looking at this....
http://allmowerparts.wss-pro.com/pa...TRACTORS_M047SBX/19260010/1926C032B0106100020
it shows 2 plates #14 in the little upper window that attaches to the frame.... would that work?
Here is a blurry picture of what comes with the blower im looking at...... what would i need to mount it to my 2320?
   / 2305 and 2320 front snowblower quickhitch the same? #4
Yes, does are the plates that you need. Pretty sure they are the same for the 2305 and 2320. You also need the drive shaft that connect to the middle PTO. I don't see it in your picture. Here are a few picture of my 2305 snowblower attachment.
thanks for the pics!!! very helpful.... i dont think the 2305 mount will work.
Im awaiting a call back from the dealer on a 2320 mount.
Anyone with a 2320 mount.... could you post pics like the above 2305 so i could see the difference?
thanks all!!!!!
   / 2305 and 2320 front snowblower quickhitch the same? #6
If you visit jdparts.com you will see they have different kits and would not be interchangeable.
   / 2305 and 2320 front snowblower quickhitch the same? #7
Hmmm, what makes you think that the 2305 plate mounts would fit? If you look at the link that you post, #14 is the same part number for the 2305, 2320, ect.
   / 2305 and 2320 front snowblower quickhitch the same? #8
saleenlimited
looking at this....
The piece you returned is what you want as it allows tool free switching between mower and front hitch. The returned piece would require a mower bracket that is quick release style but it should come with that frame you returned. Check LVB24899. Otherwise item #14 is for the front hitch only and you will be wrenching these brackets on and off along with your mower brackets as you switch between mower and front hitch.
