fuseboxer
- Joined
- May 4, 2011
- Messages
- 215
- Location
- Gaines, Michigan
- Tractor
- two john deere Sabres (2554-Scotts) and 4410 john deere ,Allis Chalmers WD , 5' Cub Cadet Zero turn
Todays project has come to a halt and I need your help. I am stuck in the middle of a project to change the leaking seal on my left front wheel on my JD4410. Many JD compact tractors are identical or very near to the one pictured. The wheel came off easy with air gun, the hub asm with its eight bolts comes off with a low power air gun. The hub wheel asm breaks free easy by use of a air chisle in the indent area provided to seperate the two. The asm is in my very large vise and no gear puller nor my bearing puller will disassemble the asm pictured. The "C" clip was easy to take off. The service manual calls for page 638 = item #6. Press the hub shaft (I) from the final drive cover,bearings, and bevel gear. I do not have a press.
Anybody have any ideas where to go to pay for a press job or is their a way make a quick press at home? You experts who did this in the past know if I will need to press it together after I get it apart or can I tap/hammer the hub shaft with splines back together? **** HELP ****SOS
