Results 1 to 10 of 14
10-04-2011, 07:27 PM #1Bronze Member
- Join Date
- Aug 2008
- Posts
- 70
- Location
- Tar Heels Baby!
Quick question about new FEL
Just got the 200CX FEL and ballast box for our 2305 and I see this attachment will probably be my favorite. Quick question on the reattaching. Is it normal for the hydro fittings to ooze hydro fluid when making the hose attachments? Is this being caused by the moving of the control stick prior to the hose reattachment, which is suggested in the manual for the reattachment procedure?
JD 2305 / 54C MMM w/mulching kit/ Leinbach L7200JR PHD/ 200CX FEL with 53" bucket and rear ballast box
10-04-2011, 07:59 PM #2Gold Member
- Join Date
- Dec 2009
- Posts
- 490
- Location
- Finger Lakes Region of NY
- Tractor
- 2007 John Deere 4320 Cab Tractor
Re: Quick question about new FEL
When you remove the fel is when you relieve the pressure prior to taking the hyd. lines off. This is what you are doing when you move the control lever around.it is normal for a little oil to come out when connecting or disconnecting hyd. lines because obviously there is oil in them!
JD 4320 Cab,6' KK Brush Hog{Old Heavy Version}, 6' Woods Finish Mower, 400x FEL 73" HD Bucket, 3rd Function Kit Installed, 6' AF11 Snow Blade, 60" Root Rake Grapple, Wallenstein FX-90 Skidding Winch...
10-04-2011, 08:24 PM #3
Yes they all slobber some when connecting and disconnecting. One problem can occur when you disconnect the loader and because of increasing air temps. or the loader settles a little can cause higher pressure in the disconnected line which makes it difficult to hook back up, as the pressure on the check ball must be overcome. Sometimes that is not so easy to do. If you can push against a clean piece of wood, or cover the ball with a couple of layers of shop towel then you can rap it sharply with a piece of wood like a hammer handle. The shop towel keeps you from taking a shower in oil and also helps protect the ball. Don't hit it with metal, as you are liable to damage the ball and cause leakage.
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
10-04-2011, 08:25 PM #4
Yeah, before the couplers seat tight you are compressing the ball stops which allows some loss of fluid. No problem there.
What you do have to worry about is when you can't recouple them because pressure wont allow you to compress the balls, there are several threads about how to deal with that, so I wont get all into it now, just warning you that it is fairly common and if it happens don't panic or think something is broken.
There are a few tricks to releasing the pressure, when you do, much more fluid is lost and can really fly out with force so you have to be careful.
You can search for threads like, "can't attach my loader hydraulic lines" or something along those lines to find the solutions.
JBJD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
10-04-2011, 08:26 PM #5
Wow. "great minds think alike"
James K0UA
10-04-2011, 08:29 PM #6
OK, James was giving the same advice with more detail as I was still typing.
So you see it is something that's happened to many of us, and you may experience if you remove your loader often, especially if you leave it off for extended periods.
10-04-2011, 08:30 PM #7JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
10-05-2011, 08:37 AM #8
You can make a tool to relive the pressure for under $10. It's one of those things you don't need until you need, and then you realllly need it.
NC
My hills have hills.
10-05-2011, 08:51 AM #9
wow thats homemade? great job.
10-05-2011, 08:53 AM #10
Looks good just remember to put a heavy rag over it.
I use to have the problem all the time with my truck mounted snow plows, I would just tap the ball against the plow to relieve the pressure, get a little extra ooze.
But when I had it happen to my loader, it had some serious pressure and when I got it to relieve I took a shower in H fluid
Similar Threads
Loader FEL and hyraulic question.
By kbensmiller in forum Kubota Owning/OperatingReplies: 2Last Post: 04-07-2011, 12:10 PM -
Have a JD 870 FEL hydraulic question
By DennisH in forum John Deere Owning/OperatingReplies: 3Last Post: 08-23-2010, 04:06 PM -
Grapple Grapple question, how are your Hyd Quick Connects mounted on the FEL.
By dex3361 in forum AttachmentsReplies: 12Last Post: 01-22-2010, 08:56 PM -
Quick FEL question - Teeth or no teeth?
By jct-mo in forum Mahindra Buying/PricingReplies: 15Last Post: 05-17-2008, 01:40 AM -
Front-End Loader Wanted: way to quick attach and detach the FEL bucket
By rickmacheske in forum AttachmentsReplies: 20Last Post: 05-10-2007, 02:56 PM
