cast_and_blast
Gold Member
Hello from not-snowing-yet Minnesota!
Just ordered a Original Tractor Cab for my JD 2305, been blowing snow without it for 4 years and finally decided that enough was enough. Last winter in MN was especially snowy and it pushed me over the edge. Got the cab, safety glass windshield and electric wiper and will be working over the next couple of weeks to get them installed. Curtis Cab was more of a "permenant" install than I wanted - I'll be taking the cab off in the Spring every year.
3 questions:
1. I've read the stories of difficult installations of the Cab- any tips or suggestions?
2. I want to add a heater and have pretty much dismissed any electric only heater or in-cab propane heaters - I think the best solution is to use the heat from the liquid cooled diesel. To that end, I've found a heater that I'm iterested in here: Model 4000 Heater
Are others using something similar and, if so, how did you mount yours with the Original Tractor Cab? I was thinking I would install on the left side and run the heater hoses through the oversize slot for the brake pedal. Just not sure what I could mount the heater on or to?
3. Also want to add at least 2 forward cab-mounted LED lights (probably 1 rear facing too) along with switches for them. I've seen the LED's from Northern Tool for $40 each - are they bright enough and are they decent quality? Any other reasonably priced LED's that folks recommend and/or have had good luck with?
Thanks for your help and advice!
Scott
3 questions:
Scott
