Originally Posted by
KML
Have never done this myself (I have a land pride RFM) but this is "supposedly" from the 272 manual.
1
Park the mower on a level surface; pull out the J-pins located on both sides of the mower to release the three-point hitch. Remove the pin at the top of the mower and move the draft arm out of the way. Push the button on the side of the driveshaft and slide the shaft off the mower gearbox.
2
Pull back on the tension arm on the deck to relieve the tension on the belt. Slide the belt off the tensioner sheave and slide the deck spring off.
3
Remove the two 10mm bolts holding down the belt guard. Remove the four lock nuts holding the gearbox to the mounting plate. Raise the mounting plate high enough to slide the belt off the bottom pulley under the gearbox. Slide the rest of the belt off the mower deck.
4
Slide the new belt under the gearbox pulley and reinstall the four nuts holding down the gearbox. Follow the belt routing in the picture provided.
5
Reinstall the spring and tighten down the belt guard.
