Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Dec 2009
    Posts
    29
    Huntsville, ON Canada
    JD 2520
    Default rear led work light on 2520
    Just installed a rear led work light ( 24 watt ) on my 2520, works quite well.
    Attached Thumbnails Attached Thumbnails rear led work light on 2520-dsc01743-jpg   rear led work light on 2520-dsc01738-jpg   rear led work light on 2520-dsc01742-jpg
  2. #2
    Silver Member RaisedonDeere's Avatar
    Join Date
    Feb 2011
    Posts
    107
    NY
    2011 John Deere 2520
    Default Re: rear led work light on 2520
    Quote Originally Posted by lowechj View Post
    That looks very nice.. Where did you purchase it, how much and was it easy to wire in?
    Thanks
    2011 JD 2520,
    200cx 61" bucket,
    Artillian Loader Forks
    62D MMM, Ind lift
    54" JD snowblower, Remote spout
    JD I-Match
    Ballast box
  3. #3
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,072
    north idaho
    Kioti DK45SE hst cab
    Do you have any idea as to how the light output compares to a standard 55 watt tractor light?
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  4. #4
    Join Date
    Jan 2011
    Posts
    124
    Bobcat T200
    I bought two of the same one for my Case 1816. I had two of the round ones, and they worked well for a while. One blew out, and I decided to upgrade the front lights by using the square ones for the front, and moving the one good one to the rear.
    I used them for plowing snow and they were great. My decision was based upon the very low current draw. The Case doesn't have a real alternator.
  5. #5
    Platinum Member brokenknee's Avatar
    Join Date
    May 2010
    Posts
    558
    South of Moose Lake MN
    Quote Originally Posted by RaisedonDeere View Post
    Thanks
    Quote Originally Posted by grsthegreat View Post
    Here is one link I found, not cheap.
    24-Watt LED flood light
    rear led work light on 2520-led-light-png
    "Clarity to Agreement" Dennis Prager
  6. #6
    Member
    Join Date
    Dec 2009
    Posts
    29
    JD 2520
    Company is So Brite Lighting in Milton, ON. They come in round or square 18, 24 and 27 watts. Mine is the 24 watt, draws 2 amps and cost $70.00 cdn. My 2520 has 2 wires behind the rear seat that are for a rear light and go directly to the light switch so it was a case of putting two bullet connectors on the light and connecting it up. In the spring I might figure out to put one that would shine forward as I find the fel blocks the headlights when it is up.
Similar Threads
  1. LED work light
    By InThePines in forum Kubota Owning/Operating
    Last Post: 11-15-2011, 10:53 PM
  2. Rear Install Work Light
    By reed52 in forum Kubota Owning/Operating
    Last Post: 12-28-2010, 09:34 AM
  3. Rear Work Light For L3240
    By kcender in forum Kubota Owning/Operating
    Last Post: 07-04-2010, 10:57 PM
  4. B7100 Rear Work Light
    By Tig in forum Kubota Owning/Operating
    Last Post: 12-15-2009, 10:58 PM
  5. 2210 rear work light connector behind seat
    By Ray2210 in forum John Deere Owning/Operating
    Last Post: 11-15-2005, 08:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
