Results 1 to 7 of 7
  1. #1
    Gold Member cast_and_blast's Avatar
    Join Date
    Dec 2005
    Posts
    494
    South Metro, Minnesota
    JD 2305
    Default JD2305 with MC519 mounted on 3 point hitch
    Hi -
    I've had this setup for a few years now and I don't think I've shared it here...I was taking some pics of my cab and LED's (different thread on TBN) and snapped a few of my MC519.
    Many of us were less than thrilled with the collection system from JD and some have used Protero or other systems instead. I found a used MC519 and a used PowerFlow and customized them for use on my 2305.
    Here is a shot of the whole unit from the right:
    JD2305 with MC519 and Original Tractor Cab by sgergen, on Flickr
    Here is a closer shot from the right to show the hitch:
    Right side custom hitch MC519 by sgergen, on Flickr
    Here is the underside from the back of the MC519:
    Underside mount points for MC519 by sgergen, on Flickr
    Here is the left side to show the hitch:
    Left side off custom hitch for MC519 by sgergen, on Flickr
    Here is a closer shot of the front of the custom hitch:
    Custom hitch - MC519 by sgergen, on Flickr
    Here is a close shot of the toplink portion of the hitch:
    Top link for custom hitch MC519 by sgergen, on Flickr
    I've been very pleased with how this unit performs. The only negative is the length of the chute that goes from the powerflow to the front of the unit - it's just long enough. I think if I got a shorter toplink I could pull the unit forward about 4"-6" which would be welcome. It's easy on and easy off too. The MC519 goes up and down with the 3pt hitch which goes up and down with the mower deck. I can keep the MC519 suspended and still have the mower deck completely lowered. It's also really easy to dump and is quite effective when it's an extra 2 feet in the air.
    The whole thing (used) was less than the MCS from JD ffor the 2305 including $200 to have the hitch custom made (materials, labor).
    Good luck!
    Scott
    Last edited by cast_and_blast; 11-16-2011 at 01:34 PM. Reason: Corrected a linked picture
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,733
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: JD2305 with MC519 mounted on 3 point hitch
    Nice fab job.
    Now add the hyd. dump to the MC519 and enjoy another level of "fun". "thumbsup:
  3. #3
    Join Date
    Dec 2005
    Posts
    494
    JD 2305
    Thanks!
    I've thought about the hydraulic dump, but the top swivels and the base dumps - it would be kinda complex to get everything "just right".
    I can usually mow my entire 1.5 acres with only 2 empties, so not sure it's worth it for summertime. Leaf shred/pickup in the fall is a different story as I have serval LARGE maple trees that drop many, many leaves.
    Scott
  4. #4
    Bronze Member Propjob's Avatar
    Join Date
    May 2008
    Posts
    85
    Seacoast NH
    JD 2305
    nice job!!!
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,733
    Upper Midwest USA
    The rig I use with hyd. dump.
    Attached Images Attached Images
  6. #6
    Gold Member kevinwak's Avatar
    Join Date
    Aug 2011
    Posts
    473
    Northern Alberta
    John Deere 2520
    Default
    I have thought of getting the powerflow blower for my 62D and then making a large plywood or sheet metal box with imatch compatable hitch. I would then make a power opening rear gate/dump on it. Maybe one day
    2007 F150 SCab 4X4
    2011 JD 2520
    Box blade, MMM, FEL, Landscape rake, PHD, Rear Snow blower, Rototiller, 50 year old 8 foot disc
    Sylvan 2520 Pontoon Boat
    Honda 919
  7. #7
    Join Date
    Dec 2005
    Posts
    494
    JD 2305
    Quote Originally Posted by beenthere View Post
    Slick!
Similar Threads
  1. 2 point to 3 point hitch
    By lstork in forum Attachments
    Last Post: 02-10-2013, 09:36 PM
  2. 3 point receiver hitch (completed)
    By pharmvet in forum Projects
    Last Post: 10-13-2011, 10:42 PM
  3. 1715 3 point hitch
    By Kosmo in forum New Holland Owning/Operating
    Last Post: 10-06-2011, 10:32 PM
  4. Agco ST30X 3 point hitch bleeding down
    By swamptiger626 in forum Hydraulics
    Last Post: 09-23-2011, 12:32 AM
  5. TC-26DA 3 point hitch noise-skip?
    By Chico in forum New Holland Owning/Operating
    Last Post: 07-11-2011, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
